Can a monkey outrun a bullet and still save her litter?
  • Thread starter Thread starter powergirl
The discussion revolves around a series of tricky questions and riddles shared among participants. Key questions include the amount of soil in a hole, the safest room for a condemned murderer, and a math challenge involving sequential additions. Participants engage in solving these riddles, offering various answers and reasoning, with some humor and banter included. The thread showcases a mix of logical puzzles and lateral thinking challenges, encouraging creative problem-solving among the members.
  • #351
There seems to be no solution when you treat the three groups, men, women, children as distinct but if you consider that each child is also male or female then consider a female child as being half a woman so should be charged half the fare for a woman as well as the fare for a child so 5/8 + 1/5 dollars in total and similarly for a male child with the fare in this case being 5 + 1/5 dollars, then 4 male children plus 96 female children would give you 100 passengers and 100 dollars.
  • #352
evra said:
there is! just do your best and see. if you can't, that does not mean that there is no solution.
Clearly there is s trick to it, as
10x + .2x + 1.25x = 100 does not have an integer solution.
  • #353
If you were to charge pregnant women the fare for a woman plus the charge for a child i.e. 5/4 + 1/5 dollars that would give a solution of 15 pregnant women, 21 non pregnant women, 60 children, and 4 men. The issue would be whether to count a pregnant woman as two passengers, but since they would be taking up one seat I would think they would be counted as one passenger.
Another thing that comes to mind is that perhaps there is a difference in the fare for a male child and a female child in the same way as for adults i.e. an 8 to 1 ratio male to female then let b be the number of boys and g be the number of girls, both natural numbers or zero, and let 1/f be the fare for girls, then the following two equations could be used to fix the two different fares for girls and boys:
b + g = 5
b*(8/f) + g*(1/f) = 1
these can be solved for f by noting that b must be a natural number or zero and must be less than or equal to 5 the first constraint means f must be equivalent to 12 mod 7 and the second constraint in addition to the first means that f must in fact be 12.
Then that leads to the following two simultaneous equations:
m + w + b + g = 100
10*m + (5/4)*w + (2/3)*b + (1/12)*g = 100
where m is the number of men and w is the number of women both natural numbers or zero.
If a solution exists it can be found by brute force I expect, I look forward to seeing the solution! (if it exists of course).
  • #354
I would consider that a cheating answer. Charging a pregnant woman for her unborn child is unheard of.
  • #355
evra said:
i have a bus that takes 100 passengers and i need only 100dollars id the bus is full. the fare for;
1 man is 10dollars
5 children is 1dollar
4 women is 5dollars
i need the bus to be full and i need 100dollars only out of it..
how many children, men and women should I've in the bus??
Perhaps we are overthinking the answer.
I can answer the question quite simply, really:
Q: how many children, men and women should I've in the bus??
A: 100.
  • #356
b + g = 5
I've made a bit of a mistake in the above; there are 6 possible values of f from those equations of which 12 is one.
A: 100.
Yes of course!
  • #357
Soca fo so said:
This might be a stupid question, but is the driver included in the 100 passengers?
no he's not!
  • #358
there is! very correct infact! try!
  • #359
A: 100.
lol! nooo that's not it.
  • #360
You skipped over the pregnant-woman-solution.
So is that it?
  • #361
Here's an alternate solution: we fill the bus with 100 children and buy them ice creams from the change.
  • #362
If the bus driver is one of the 100 passengers, I still don't think there's a solution, although if he has to pay a fee just like the other passengers (IE, there are 101 seats), then I believe there are a few solutions (I get 3 of them).
Otherwise, there's obviously something wrong-- either the problem isn't stated correctly, or there's a trick (like having some people not pay, or paying full fare for 4 women when in fact , say, only 2 of them actually show up). If evra posts the "intended" solution, I'm sure we can determine which is the case.
DaveE
  • #363
No, there may be an integer solution to the puzzle, but there is not an integer solution to the equation I posted. The solution to the equation I posted is x=8.733. So clearly there's some trick to the puzzle.I surmise that the trick is that, through fancy footwork with the wording, at least one of the criteria need not be met. Either the solution does not actually require 100 people, or it does not require 100 dollars.
  • #364
LOL. I didn't even notice.
But there's also no integer solution to 10x + .2y + 1.25z = 100 with x + y + z = 100.
  • #365
So is that it?
no the pregnant woman stuff is stupid. i don't want to talk about it.. all the seats should be occupied. and we've 100 for the passengers.
  • #366
You know, I don't believe he said it all has to be on the same trip.
Is there an integer solution to 10x + .2y + 1.25z = 100 with x + y + z = 200?
  • #367
DaveE
the driver is not paying. and we have 100 seats for 1OOpeople and all of them will pay.
  • #368
No there isn't.
  • #369
hahahahahaaha.. that's not correct.. you are sooo funny..
  • #370
Yes, there could be a valid solution if you say that the children are men or women, but I'd also consider it a cheating one. One does not pay two fees for two different criteria (age and gender).
  • #371
no manipulation. children are children, men are men and women are women. no prenancy, no bisexual no other thing!
  • #372
I PM'd you. Did you get it?
  • #373
No bisexuals? That wasn't even mentioned.
  • #374
He's being preemptive. He means no tricks.
  • #375
Some of the children are young enough that they would be in their parents' arms. Thus, they are charged a fee totalling to $100, but they do not take up any of the 100 seats.
Unfortunately, I think there are many solutions to this one.
Here is one:
0 men.
28 children (28 seats, $5.60)
72 mothers (72 seats, $90)
babes-in-arms (0 seats, $4.40)
The bus is full, all 100 seats are occupied, driver has received $100.
  • #376
unfortunately you are wrong uncle Dave. there is only one answer to it. lol! I will send the person who answers a present.
  • #377
yes.. and i replied.
  • #378
Hmm, I'm confused. :confused:
Is Dave's statement correct or not?
If it is, WolframAlpha gives me the following solutions:
{{x == 0, y == 25, z == 76}, {x == 0, y == 50, z == 72}, {x == 1, y == 50, z == 64}, {x == 2, y == 50, z == 56}, {x == 3, y == 50, z == 48}}
  • #379
evra said:
unfortunately u are wrong uncle Dave. there is only one answer to it. lol! I will send the person who answers a present.
Are you saying there are no children being carried by their parents?
  • #380
Do all the passengers board the bus at the same stop? Because thinking about it, where I'm from at each stop generally some passengers get off a bus and new ones get on so in theory you could have a full bus at every stage of the journey while at the end of the bus route more than 100 people would have traveled on the bus. Is this bus such a bus?
  • #381
no child is carried by his or her mum. all the children are capable of taking seats.
  • #382
no its not! it is a bus that goes from a destination to the other without a stop and it won't move without being full and can't collect less or more than 100Dollars.
  • #383
I think we give up.
  • #384
DaveC426913 said:
I think we give up.
Uncle Dave you don't have to. you are stronger than that.
  • #385
I think after 40 posts, we're stumped. Time to move on.
  • #386
It's not possible. The equations are 10x+1/5 y + 5/4 z = 100, and z+y+z = 100, which gives 7(28x+3z) = 1600 by substituting y from the last equation into the first. 1600 is not divisible by 7, but 28z + 3z is an integer.
  • #387
It's not possible when interpreted literally. Obviously there's a trick to it.
But evra is determined to drag it out as long as possible.
What's black and white and red and can't turn around in hallways?
  • #388
A hallway painted black and white and red?
  • #389
A nun with a javelin through her head! :biggrin:
  • #390
Hello my people! i am very very very sorry to all of you. i made a small mistake on the puzzle and it changed everything. forgive my guys, i was a little bit away. and especially to Uncle Dave, I am really sorry. and remeber that to make a mistake is human though not scientific and i hope u will forgive me. anyway, the correct one is;i have a bus that takes 100 passengers and i need only 100dollars id the bus is full. the fare for;
1 man is 10dollars
1 woman is 4dollars
Honestly i am sorry for the mistake. try this one for me please and let's forget the past.
  • #391
At least you've led us on a merry chase! :smile:
7 men, 3 women, and 90 kids
  • #392
It would have gone a lot easier if you had bothered to work out the solution for yourself, instead of just continually telling us to thiiiiiink!
  • #393
If more than 5 different people here on PF say it's not possible, that might give a very slight indication that perhaps it is not possible. :wink:
  • #394
yes, you are all right.
  • #395
Hah! Glad I only spent a few minutes on that! I thought I was being dumb.
  • #396
Does that mean you'll send us a present now? :rolleyes:
  • #397
:biggrin:
Yeah! Pony up evra!
  • #398
yes, PM me your postal Adress.
  • #399
Can you make it a gold membership for yourself instead (US$14.99)? o:)
  • #400
hahahaha! ok i will.
10K
  • Sticky
