Can a Vertical Jet Engine Replace Helicopter Blades for Hovering Crafts?
  • Thread starter Thread starter Hornbein
    Helicopter Idea
55 replies · 6K views
Hornbein
Summary: Have a hovering craft powered by a jet engine.
Instead of helicopter blades have a vertical jet engine embedded in the craft. Steer via thrust vectoring.
The angular momentum of the jet engine might not provide enough stability but surely there is some way to get that.
A simple jet engine pointing down requires a lot more power than the blades do. The way to understand this is to see how each would fall with no power. Each design requires only the amount of power to counteract the descent at the "zero power" speed. With a jet engine and no power, the helicopter would fall like a stone. It takes a lot of power to counteract that. A regular helicopter would fall a lot slower because the blades slow it like a (bad) parachute (see autorotation). It takes a lot less power to counteract that.
Another problem is that the aircraft would be harder to control. The act of keeping upright with a jet engine pointing down requires very fast vectoring. Modern controls can do that, but it makes the stability of the aircraft completely dependent on the control system. Helicopter blades can be above the vehicle, which is stable. The blades pull it up and keep it upright. A jet engine can not be above the vehicle because of the hot exhaust and the disturbed airflow. With the jet engine below, the vehicle is balanced on top of the jet thrust and is unstable.
EDIT: The crossed-out part is the "Pendulum Rocket Fallacy". It is not true. Thanks, @hutchphd .
Once you put that much power in a "helicopter", it is a shame to not add some wings and get a much faster vehicle. Examples are the Harrier jet and the F-35B.
CORRECTION: The F-35B also uses a large jet-driven internal fan for its takeoffs and landings. It is STOVL (Short TakeOff Vertical Landing). I think it may have some limited vertical takeoff capability if it is light enough.
Or you can look at batteries and electric power. These people are getting over 250 mile range, vertical takeoff, and vertical landing with battery power: https://www.beta.team/aircraft/. It's larger than you are interested in, but gives an idea of what can be done with batteries and electric motors. They claim a useful load of 1400 lbs or six people. And it has a wing, so could glide to a landing on a total power loss.
If you search the N number (N250UT), it has flown several 1.5 to 2.0 hour flights recently.
WITW? They do indeed claim VTO on their website, but how? I don't see any pics of the configuration for VTO on their website, and don't see any way to either tilt that aircraft onto its tail (plus the tail rotor is way too small for a balanced VTO), or to tilt the rotor.
How does it take off vertically?
It looks like it is actually a quad-copter. It doesn't sit on its tail. In the photos, you can see 4 rotors aligned with the two front-to-back braces on the sides. The rotor on the tail is for forward motion after the vertical takeoff.
If it works, why isn't there a video of it working?
  • Love
Ask and ye shall receive:
The V-22 Osprey, One of the most maligned aircraft in history.
And the AV-8B Harrier:
Vectored thrust engine.
You must have X-ray vision or something --- I can't see anything like that
No, not the V22 or Harrier: I have seen at least one of those in VTOL mode with my own eyes. However I was referring to the scam design presented in #7: I don't see any evidence that the fraudsters engineers have produced a working model that can VTOL, and there is no evidence of rotors on the images of N250UT.
The first photo on their website is clearer. You can see the 4 rotors, but they blend in well.
Yes, funny how CGI always looks clearer.
Weird. I see that now in the line drawing and overhead pic with the rotors aligned front-to-back for aero flight forward, but the pictures on their website show only bumps in those two braces, not rotors in the test flights.
It's not clear how far along they are in development. It looks like they have a flying plane without the rotors and the final goal is to get vertical takeoff with rotors. But It looks to me as though they still have work to do.
They are showing you two pictures, one of an aircraft with little bumps on its wings that can fly, and one of a model (or CGI mockup) of something with 4 "rotors" for which there is no evidence, or indeed direct claim, of its ability to fly. The association of the picture with the thing that flies is deliberately deceptive, and this deception clearly fools at least some of the people at least some of the time.
About as far as I am with my warp drive - look, here's a picture
Yes, I have a flying plane without the warp drive.
No s**t.
  • Haha
I do not fault them for proceeding in a cautious, step-by-step development. They are just showing some of their work and ideas. I think the first photo is of a model. It's a concept that definitely can work eventually, but the devil is in the details.
  • Sad
  • Wow
Woo-hoo! I'll buy a ride on that baby! How much, and what star date should I put on my calendar? Will I be able to meet Scotty? :smile:
  • Haha
It seems to me that they have skipped straight from blue sky thinking to marketing, without even bothering with a proof of concept.
Then why aren't they saying that?
FactChecker said:
It's a concept that definitely can work eventually.
As is my dilithium crystal warp drive.
Yeah, those damn details. Evidence is another thing that I find troublesome. Oh and regulators who insist on not deceiving potential investors (of course I don't live in the land of the free to defraud).
On closer examination, that's exactly where they are right now. They are currently flying it in airplane mode. Flightaware shows a 2 hour 5 minute flight on June 26, 2022. That's impressive for a battery powered airplane.
The concept is vertical takeoff in a quadcopter configuration, then use a fifth motor to move it horizontally. The horizontal velocity generates enough lift from the wing to unload the lift rotors, after which the lift rotors are stopped and stowed. The idea of rotors for vertical takeoff and a separate propeller and wing for horizontal flight appears to have originated with Jay Carter. He built a gyrocopter with a wing to demonstrate the concept, and was able to show proof of concept: http://carteraero.com/home2/ and https://en.wikipedia.org/wiki/CarterCopter.
On the other hand, Joby Aviation has a more conventional quadcopter design with tilting motors: https://evtol.com/news/joby-evtol-aircraft-surpasses-150-miles-flight-test/. Since then, it crashed due to a "component failure". But it was flying that day: https://globe.adsbexchange.com/?icao=a6df63&lat=35.882&lon=-121.198&zoom=12.5&showTrace=2022-02-16. Search the N-number N542AJ for more information.
You are either embracing or dangerously flirting with the Rocket Pendulum Fallacy. The pendulum rocket fallacy is the incorrect idea that a top mounted rocket will make the vehicle more stable than a bottom mounted rocket. Robert Goddard's early "puller" rockets were not more stable than the later "pusher" ones. In either case it is the misaligned rocket that supplies unwanted torque, not gravity. Goddard clearly figured this out early.
Source? It takes no effort for me to hold a stick in a vertical position with my fingertips. It takes constant concentration and feedback control for me to balance that same stick in the palm of my hand and keep it vertical...
I see it as just a webpage to represent their company. They are a small company. Apparently, they have a military contract to develop a quad-copter that converts to regular airplane flight. This is not unusual.
They are just showing where it is heading. They are not asking you for $, so it's not a con job.
A gross exaggeration. This concept is very realistic. There have been several similar efforts. When battery technology improves, it might be a real winner.
I assume that a serious investor can get a lot more information. (Their current effort has military funding.)
I stand corrected. It is more complicated than I indicated.
Still, it seems to me that the vectoring required to correct a lateral disturbance is better if it points in the desired direction of motion. That seems true in a "puller" position but false in a "pusher" position.
Source?
Here's one. https://second.wiki/wiki/falacia_del_cohete_pc3a9ndulo
And a video
The crux here is that the thrust vector for a rocket is rigidly attached to the rocket. If you could always pull the nose up then you would stabilize but that is not easy to do. Goddard figured this out pretty quickly as I recall. (I read his biography 60 years ago! )
