vanesch
Staff Emeritus
- 20
selfAdjoint said:But can the photon, however configured, interact with more than one retinal cone? The opsin molecule in that cone is only capable of telling the brain "I was excited by a wavelength somewhere in a distribution about X", where X = 556 nm, 535 nm, or 44 nm, depending on the molecule.
There are two possible responses to this, according to one's view on QM.
The first one ("traditional") is: if you consider that this interaction is a *measurement* then the answer is of course no. You apply the Born rule to your photon superposition in the momentum basis, and thus you pick out a probability for each of those components to be chosen.
My pet interpretation, however, which is more MWI-like is:
This interaction of the EM quantum field and those opsine molecules is just a unitary process described in QED language. This then means that you simply entangle the different states of the different opsine molecules with the photon superposition. This is what a quantum chemist should tell you, after he has written out his hamiltonian of the interaction of photons with his molecules.
So yes, this then entangles with different nerve states (K/Na balances in superposition) etc... until your consciousness has to make the ultimate choice, using the Born rule, whatever that may mean. Upon making this choice, you can then track back that this came down to exactly one excitation of one molecule (in the chosen branch).
In practice however, there is of course no observational difference because all these entanglements are so hopelessly complicated that we will never be able to use them to perform interference experiments, discriminating between superpositions and stochastical mixtures.
So, if our eye were sensitive to a single-photon impact, you would get A SINGLE color sensation, red, green or blue, upon the impact of a white photon.
But as our real eye needs several photons in order to do so, and as each one will give rise to a different sensation, this will probably never be experienced.
A single photon: you don't see anything (because we need more)
Several photons: we will get stimuli from different types of molecules and experience "white".
cheers,
Patrick.
