SW VandeCarr
- 2,193
- 77
Can a curve, connected and differentiable everywhere, fill the x,y plane? My view is that a curve can only fill the x, y plane if it has singular points.
A differentiable curve cannot fill the x,y plane unless it contains singular points, as established in the discussion. The proof referenced utilizes Sard's lemma, which indicates that a mapping from [0,1] to [0,1] x [0,1] cannot be everywhere differentiable. The notion of a "negligible set," defined as a subset of R with measure 0, is crucial in understanding the limitations of differentiable space-filling curves. The conversation also touches on the possibility of analytic curves being space-filling when ignoring singularities at self-intersections.
PREREQUISITESMathematicians, analysts, and students studying topology and real analysis, particularly those interested in the properties of curves and their dimensional implications.
quasar987 said:The first link for me was http://at.yorku.ca/cgi-bin/bbqa?forum=ask_an_analyst_2005;task=show_msg;msg=2554.0001.0001 and there is a proof there based on Sard's lemma. The proof is for a square-filling curve but as far as I can see, the proof holds without change for a space-filling curve.
The notion of a "negligible set" is used in that proof. In case you don't know what that means, by definition, a subset of R is said to be negligible if it has measure 0. The measure of a subset of the real line is a measure of its "length". Indeed, the measure of [a,b] is b-a and in particular, [0,1] has measure 1 and so it is not negligible.
Tibarn said:You can have a space filling curve that's differentiable almost everywhere, but that's about it.
SW VandeCarr said:Thanks Tibarn. When you say 'almost' everywhere, I assume you mean after you have excluded self-intersecting points. Is that correct?
