Mentor
- 50,923
- 26,963
jaumzaum said:The situation I was describing was a bound electron in the position x=R going to the position x=4R by itself, while still bounded to the atom and in the 1s orbital with that characteristic energy of -13,6eV, no external work being made.
Even if we put aside all the valid issues that have been raised with this in terms of QM, and just consider a classical electron orbiting a classical proton with the given energy, and rule out the electron radiating any energy away (which classically it would, it would not remain in a stable orbit but spiral into the nucleus while emitting radiation), we still need to be clear about how classical orbits work.
If the electron's total orbital energy is -13.6eV, that's its total energy at all positions in its orbit. If its orbit is elliptical, so that its position is not always x=R, its total energy is still -13.6eV at all positions in its orbit. That means that it is impossible for the classical orbit to reach any position where the potential energy would be greater than or equal to -13.6eV, no matter how elliptical it gets, since, as you correctly believe, it is impossible for its orbital kinetic energy to be zero or negative in the classical model. That means that even the most elongated possible elliptical orbit would have to have its greatest distance from the proton less than the distance at which the potential energy is -13.6eV. In particular, it would be impossible for a classical elliptical orbit to reach x=4R, since the potential energy there is -6.8eV, which is greater than -13.6eV.
So another way of illustrating the issue you are having is that you are trying to combine two inconsistent views of the electron. You are trying to think of it like a classical particle with a position that is moving in some kind of orbit; but you are also trying to make its orbit have properties that a classical orbit simply cannot have. The "negative kinetic energy" at x=4R is simply a manifestation of this underlying problem. The way to resolve it is to stop trying to combine two inconsistent views of the electron: i.e., to understand that the QM model of the electron is simply incompatible with any way of thinking of the electron in a hydrogen atom as a classical particle "orbiting" the proton. That simply doesn't work.
