Can an Inductor hold a charge?
  • Context: Undergrad
  • Thread starter Thread starter physMommy
    Charge Inductor
An inductor does not hold a charge in the same way a capacitor does; it requires a current to generate a magnetic field for energy storage. While an inductor can store energy temporarily during operation, this energy dissipates almost immediately once the circuit is broken. In practical applications, especially with larger inductors, it is crucial to power down slowly to prevent arcing due to electromagnetic inertia. Superconducting inductors can maintain a current indefinitely, but standard inductors do not retain charge outside of a circuit.
  • Understanding of electromagnetic principles
  • Familiarity with inductor behavior in electrical circuits
  • Knowledge of LR circuit configurations
  • Basic concepts of energy storage in magnetic fields
  • Research the principles of electromagnetic inertia in inductors
  • Study the differences between inductors and capacitors in energy storage
  • Explore the behavior of superconducting inductors
  • Learn about safe discharging techniques for inductors in circuits
Electrical engineers, physics students, hobbyists working with circuits, and anyone interested in the behavior of inductors in electrical systems.
physMommy
I understand that in an ideal world, an inductor will not hold a charge (when not connected to a circuit). Ideally, there would need to be a current through the inductor to generate a B-field to store energy.
I once read, that (since this is not an ideal world), an inductor actually CAN and WILL hold a charge, rather than fully discharging when disconnected from a circuit.
I'm looking for a valid argument either way.
Thanks!
It can't hold a charge, but a superconducting inductor can hold a current.
Which means that it retains it's magnetic field in the same way as a magnet holds it's field.
Let me explain where I'm coming from with this.
I was told I needed to discharge an inductor used in a simple LR circuit before completing the circuit.
Theoretically, this makes no sense as the inductor should not be charged/storing energy outside of a circuit.
Is there really a need to discharge an inductor prior to introducing it to a circuit?
I did read that in actuality, an inductor will store energy independently, to some degree.
Is this possible?
No, that makes no sense.
You might need to slowly power down a big inductor before trying to disconnect it because it may arc over if you break the circuit suddenly. (Current continues to flow because of electromagnetic inertia).
In the short term, an inductor stores energy in it's field during operation, but we're talking about fractions of a second. That energy dissipates when the circuit is broken and is gone when the current reaches zero.
Contrast the charge holding properties of a capacitor which may hold a lethal charge for several minutes or even hours if it's big enough.
Thanks, AJ!
This confirms my thoughts.
I did google the topic before and found a source which said an inductor will hold a charge/energy and needs to be discharged, but I am unable to locate that source, now. It was something I came across and wanted to verify the reliability of the source.
  • · Replies 50 ·
14K
  • · Replies 24 ·
  • · Replies 22 ·
