Can an inverse function of a special cubic function be found?
The discussion revolves around the possibility of finding an inverse for the cubic function defined as ##f(x)=3x^3 -18x^2 +36x##. Participants explore whether this can be achieved without resorting to the general solution for cubic equations, examining the nature of inverses for polynomial functions and the conditions under which they exist.
  • Some participants question if the specific cubic function can have an inverse without using the general cubic equation solution.
  • One participant suggests that the function can be expressed in a completed cube form, indicating the presence of three inverses, with two being complex for real values other than two.
  • There is a contention regarding the definition of an inverse, with some arguing that polynomials do not have inverses in the traditional sense, while others assert that they can have inverses if branches are chosen.
  • Participants discuss the injectivity of functions, with examples like ##f(x)=x^2-16## being cited to illustrate that not all polynomials can have inverses due to their non-injective nature.
  • Some participants propose that polynomials of odd degree can have inverses, particularly if they are monotonic, while others argue that this is not universally applicable.
  • There is mention of the importance of defining domains and ranges precisely when discussing inverses, with some suggesting that partial inverses can exist even if total inverses do not.
  • One participant references a paper on monotonic polynomial fitting, suggesting that monotonicity may be a key factor in determining the existence of inverses.
Participants express disagreement regarding the existence and definition of inverses for polynomials. While some argue that certain polynomials can have inverses under specific conditions, others maintain that many do not have inverses in the traditional sense. The discussion remains unresolved with multiple competing views on the topic.
Participants highlight limitations in definitions and the need for precise conditions when discussing inverses. The discussion also touches on the complexity of polynomial behavior, particularly in relation to injectivity and monotonicity.
phymath7
TL;DR
There's a simple method for finding an inverse function of a quadratic function.But I wonder whether an inverse function of a special cubic function can be found.
Like this one: ##f(x)=3x^3 -18x^2 +36x##.Is there any way to find the inverse of this function without using the general solution to cubic equation?
Mathematics news on Phys.org
I would be surprised if there was for that function in particular.
Edit to add: o obviously I'm bad at math
$$f(x)=3x^3 -18x^2 +36x$$
complete the cube
$$f(x)=3(x-2)^3 +24$$
There will be three inverses
For real values other than two, two preimages are complex
Not sure what you mean by the inverse. These polynomials don't have an inverse. If you mean to find their zeros, i.e. solve ##f(x)=0## for possible values of ##x##, then it depends on the case. Some are easy, but there is no general way to solve them other by using the formulas for degrees ##2,3,## and ##4.##
^I think the question is if the particular example is easier than the general case. This example is easier, it is a sum of cubes. I don't know what you mean by polynomials don't have an inverse, as they clearly do. The inverse is not a function so we need to choose branches. In this example we have a real branch and two complex branches. If we are only concerned with the real branch the inverse is unique.
No. they do not. E.g., ##f(x)=x^2-16## cannot have an inverse since two values in the domain map to one value in the rage: ##f(4)=f(-4)=0.## What would ##f^{-1}(0)## be? A parabola isn't injective, ergo not bijective, ergo no inverse.
Even if you meant the reciprocal ##1/f(x)## we get into trouble as soon as there are zeros of ##f(x)## as in my example.
lurflurf said:
The inverse is not a function ...
... in which case we cannot call it inverse ...
lurflurf said:
... so we need to choose branches. In this example we have a real branch and two complex branches. If we are only concerned with the real branch the inverse is unique.
You make it artificially injective. That is a different function then!
$$x^2-16$$ has an inverse. The complete inverse is multivalued, so you can chose branches if you like. That is like saying sine or exp don't have inverses, my pocket calculator says they do.
I would say
$$f^{-1}(0)=\{-4,4\}
If want a single valued inverse pick a branch.
I would say
Again, nobody calls this an inverse.
An inverse of ##f## is a function ##g## such that ##f\circ g = \operatorname{id}## and ##g\circ f = \operatorname{id}.## And if you do not define domain and range precisely to mean something else than the maximal possible, then there is no inverse. A polynomial is defined on the entire real line or on the entire complex plane, but neither has an inverse as soon as it is not linear anymore.
fresh_42 said:
No. they do not.
Over the Reals, some do and some don't. @lurflurf has shown that this one does and is fairly easy to give an equation for it.
Sorry, but this is serious misinformation. A parabola does not have an inverse. It is not injective.
Where are we that some do and some don't?
Edit: In case ##f(x)=x^2-16## then ##f^{-1}(\{0\})=\{\pm 4\}## is called pre-image of zero, not inverse! Pre-image is a set-theoretical term, inverse refers to functions.
Sorry, but my statement is absolutely correct. Over the field of Reals, some polynomials have an inverse. The fact that you have examples that do not have inverses does not contradict what I said.
Yes they do, in particular they say
given two sets A and B the relation R is a subset of their Cartesian product
$$R\subset A\times B$$
the inverse of R is defined by
$$R^{-1}=\{(b,a)|(a,b)\in R\}$$
If you are more interested in functions
it is true that not all functions have full inverses.
It is odd to say they have no inverse when it is very useful to restrict the domain and consider partial inverses.
I would say $x^2$ has a partial inverse or that is does not have a total inverse, not that it has no inverse.
Polynomials over reals do not need to be linear to have inverses consider the given example as a counter example as it has a total inverse as a real function.
Sorry, my bad. Polynomials ##x^{2n+1}## can be inversed. Nevertheless, these are the exceptions: no local extrema, and of odd degree.
You can always do the check of the derivative to see if it's monotone, so that it's 1-1. And for odd powers, limits at ##+\infty=+\infty##, at ##-\infty=-\infty##, so they will be onto.
The really hairy question is for polys into ##\mathbb R^p ; p>1##. Deciding if they're or onto.
Yes, ##x^3## itself has inverse ##x^{1/3}##. I guess having a monotonic derivative is sufficient. But not sure if it's necessary.
^positive derivative suffices
I found an interesting paper
https://www.researchgate.net/publication/292674112_Fast_and_flexible_methods_for_monotone_polynomial_fitting
that states the general monotonic polynomial is
$$a+b\int_0^x \bigg(p_1(u)^2+p_2(u)^2\bigg) du$$
and that it may be proved using the theory of Tchebycheff systems, the theory of
canonical moments, or directly.
23K
  • · Replies 53 ·
