What Is the Acceleration of a Train Slowing Down on a Curve?
  • Thread starter Thread starter Sunnie
A train decelerates from 84.2 km/h to 50.7 km/h over 15 seconds while navigating a curve with a radius of 120 m. The acceleration is calculated using the formula A = (Vf - Vi) / t, resulting in an acceleration of -5.204 m/s². This negative value indicates deceleration. The magnitude of the acceleration is 5.204 m/s², and the direction is 180° backward relative to the radial line pointing inward. The train continues to slow down at this rate while rounding the curve.
Sunnie
A train slows down as it rounds a sharp horizontal turn, slowing from 84.2 km/h to 50.7 km/h in the 15 s that it takes to round the bend. The radius of the curve is 120 m. Compute the acceleration at the moment the train speed reaches 50.7 km/h. Assume that it continues to slow down at this time at the same rate.
What is the magnitude in m/s2?
What is the direction in __ ° backward (behind the radial line pointing inward)
The formulas that I have is:
Vf= Vi + AT
Rf= Ri + Vi*t + (1/2)A*T^2
A = (Vf-Vi)/t First, solve for A: A = (50.7 km/h - 84.2 km/h) / (15 s) A = -5.204 m/s2 The magnitude of the acceleration is 5.204 m/s2. The direction of the acceleration is 180 ° backward (behind the radial line pointing inward).
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 20 ·
  • · Replies 25 ·
