Can anything conduct electricity?
  • Context: High School
  • Thread starter Thread starter Brown8633
    Electricity
The discussion centers on the concept of electrical conduction, specifically addressing whether all materials can conduct electricity under high voltage conditions. Participants clarify that while applying high voltage can excite electrons from the valence band to the conduction band, it does not equate to traditional conduction as seen in metals. Key terms such as "band gap," "Fermi level," and "ionization potential" are discussed, emphasizing that materials with larger band gaps behave more like insulators. The conversation also touches on phenomena like electrical breakdown and field emission, which differ from standard conduction.
  • Understanding of electrical conduction and insulators vs. conductors
  • Familiarity with band theory, including valence and conduction bands
  • Knowledge of Fermi level and its role in material behavior
  • Basic concepts of ionization potential and electrical breakdown
  • Research "band gap engineering" in semiconductor materials
  • Explore "Fermi level manipulation" techniques in solid-state physics
  • Study "ionization potential" across different elements and its applications
  • Investigate "field emission" and its implications in nanotechnology
Physics students, electrical engineers, materials scientists, and anyone interested in the principles of electrical conduction and material properties.
Brown8633
hi everyone.
i have always been taught that there are either insulators or conductors but can't everything conduct electricity with a high enough voltage? I know a free electron is needed to move from atom to atom to conduct electricity but if a high enough voltage is put through something does that not give a non-free electron enough energy to move to another atom?
Brown8633 said:
hi everyone.
Well materials have valance and conduction bands. The distance between the valance and conduction band is defined as band gap. As the band gap get bigger materials become more insulator because it gets harder for to excite an electron from the valence band into the conduction band. There is another term called Fermi level which determines behaivor of materials. Aplying a voltage only changes the Fermi level not the band gap.
So you can excite electrons from the valence band into the conduction band but at the end the conduction won't be the same as a metal. As well you might destroy materials.
thanks for the reply.
so the valence bands are the lower bands of the atom that the electrons populate yeah? does this mean that the amount of valence bands change with which element it is? and is the conduction band the most outer band with the least amount of electrons on and the amount of energy to move an electron from the conductive band depends on how close it is to the nucleus for example in helium there is one shell of electrons so would it take more energy to move electron in helium than radon? also does it take more energy to move electrons from a conductive band with 13 electrons than it does for a band with 1 electron?
Air is an electrical insulator. High voltage across an air gap does not conduct electricity until the electric field is sufficient to ionize the air and create free electrons. Here is a table of ionization potentials of the elements, including helium and radon:
http://environmentalchemistry.com/yogi/periodic/1stionization.html
Bob S
On a related note:
I saw an MIT YouTube footage of a thick glass rod which, when heated by a blow torch would conduct electricity.
No practical purpose, I suppose, just a physics demo.
Please note that an electrical breakdown isn't typically considered as an electrical "conduction". So while it is true that if you apply a high enough field to almost anything, you can get charges to go across it, one typically don't consider this as an electrical conduction.
In fact, one could get charge flow at levels well below such breakdown via field emission/field current, i.e. tunneling process. This still isn't a "conduction" in the normal sense, it certainly has more controlled aspect of the phenomenon.
Zz.
  • · Replies 16 ·
  • · Replies 36 ·
