Can Bulb Resistance Change with Different Voltage Sources?
  • Thread starter Thread starter Peter G.
    Resistance
3 replies · 2K views
Peter G.
"Estimating" Resistance
Hi,
So, suppose I have a bulb labelled 10 V, 12 W. This is connected to a 4 V e.m.f battery. Can I calculate the Resistance from 10 V, 12 W (Using P = VI and R = V/I) and assume that it is the resistance when it connected to a 4V battery?
Thanks!
Generally speaking, the resistance of a bulb vary with temperature. If ignore this feature, I think your answer is right.
Peter G. said:
Hi,
Thanks!
If the bulb is rated 12W at 10V, that likely means that it produces a reasonable of light at 10 V. The filament of the bulb, under such conditions, will be near its maximum operating temperature.
At 4 V, the same bulb would be operating at a considerably lower temperature. The resistivity of tungsten is very temperature dependent, so the resistance of the bulb would be much less than when it operates at 10 V .
Without a graph, however, is there any more precise method of estimation?
