Can Compact Fusion Reactors Power Small Cities?
32 replies · 6K views
Deacon James
https://lockheedmartin.com/en-us/products/compact-fusion.html
HOW COMPACT FUSION WORKS
Nuclear fusion is the process by which the sun works. Our concept will mimic that process within a compact magnetic container and release energy in a controlled fashion to produce power we can use.
A reactor small enough to fit on a truck could provide enough power for a small city of up to 100,000 people.
Building on more than 60 years of fusion research, the Lockheed Martin Skunk Works approach to compact fusion is a high beta concept. This concept uses a high fraction of the magnetic field pressure, or all of its potential, so we can make our devices 10 times smaller than previous concepts. That means we can replace a device that must be housed in a large building with one that can fit on the back of a truck.
Interesting but where is a workable machine now ?
But it’s only 20 years away
mathman said:
I like the irony!
Is that a bit like goldy?
So far, fusion for power generation (that is "economic" power generation) is always in the future. Back almost 40 years ago when I studied fusion engineering, it was 10 years away. Forty years later, it's about 20 years away and counting.
The problem with terrestrial systems with magnetic confinement is that we'll never reproduce conditions in the core of the sun, particularly the pressure and plasma density in the core. Furthermore, fusion is present in the sun, but it's p+p, or CNO-cycle process, as opposed to the easier d+t or d+d fusion we are attempting in terrestrial systems. It is misleading to liken our attempts at fusion with what is happening in the sun.
From https://nssdc.gsfc.nasa.gov/planetary/factsheet/sunfact.html
Model values at center of Sun:
Central pressure: 2.477 x 1011 bar best we can to is ~70 atm (71 bar)
Central temperature: 1.571 x 107 K ITER is attempting 150 million K (https://www.iter.org/sci/plasmaheating)
Central density: 1.622 x 105 kg/m3 or about 162 x density of water; other put the estimate about 150 x density of water.
I can get a 4000 watt generator at Target that is powered by fusion, albeit indirectly, for about $250
mathman said:
Aren't generators powered by some sort of gas combustion?
Yes, this fusion-powered generator burns gasoline, which is a pretty nifty way to store fusion power
I think it runs on propane, but still, same idea.
According the UK AEA chief and fusion expert Steven Cowley, the Lockheed fusion project and its lead researcher McGuire have placed themselves in a bit of a scandal. Apparently Lockheed released some promising preliminary results on their reactor, prompting some immediate but unsurprising queries about plasma temperature, density, etc. After some stalling came the reply, that the machine had not yet been turned on.
mheslep said:
According the UK AEA chief and fusion expert Steven Cowley, the Lockheed fusion project and its lead researcher McGuire have placed themselves in a bit a scandal. Apparently Lockheed released some promising preliminary results on their reactor, prompting some immediate but unsurprising queries about plasma temperature, density, etc. After some stalling came the reply, that the machine had not yet been turned on.
Could you please provide a reference for that.
I wonder if that's a rogue engineer or if corporate leadership knew about it. Academic fraud is not a crime, but financial fraud (stock manipulation) is.
Cowley's talk is here, and the comments on alternative fusion approaches like Lockheeds begin at 1:11. Note that though Cowley calls these particular startup American approaches 'whacko', he's very pro American mainstream research earlier in the talk.
That device at 40 seconds into Lockheed video sure resembles a Farnsworth fusor .
Fusors are indeed spherical, but they are electrostatic devices that do work on the plasma to (futilely) focus it in the center. Lockheed's device as the patent states is magnetic confinement of a thermal plasma.
Futility of a means depends on the end.
Tabletop fusors make a stream of neutrons sans uranium. Chrysler marketed them for a while. They were handy for irradiating things when you don't have a fission reactor.
They don't break even on energy though ..
Seems they have been relegated to the hobbyist world now.
http://shia.wsyntax.com/~raymond/fusor.pdf
I'm wondering about how energy is extracted once fusion is achieved?
It's rather unfair for him to label alternative approaches as 'whacko'. The simple fact is that the mainstream fusion research community has been promising results for six decades now and their approach just isn't working thus the ongoing joke. The Lockheed approach may not work but I'm glad they and others are trying.
Academic fraud should be a crime if it involves intentional deception in order to receive grants.
Probably running a steam generator or if they get fancy, an MHD generator.
russ_watters said:
...and to put it charitably, it seems overly optimistic to me.
Lockheed's approach is more about designing the design cycle and a fast pace of research rather than a specific machine design. As I've read what they are really about is developing the facilities and staff to rapidly test a sequence of devices and changes in configurations with the hope that this process will lead to a working machine in a five to ten year period.
In the failed attempts leading up to powered flight, jumping off the roof with a cape was still whacko because of a lack of a sound scientific basis. Roof jumping is not made otherwise, i.e. sound, because mainstream attempts failed.
The failure of mainstream fusion is nonetheless based on what is known, though much remains unknown. Trying something else based on known flaws or ignorance deserves the term whacko, especially given the money spent. * I don't know enough about the field to know if the particular alt-fusion attempts are necessarily flawed or random, but Cowley does.
And I'm not aware of any "promises" about early fusion attempts from scientists involved, though the pop science media consistently over hyped. Those projects usually state i) theoretical potential, ii) time to complete the experiment. ITER for instance clearly states that the project is not suitable for a commercial fusion reactor.
Cowley may have a strong opinion but not the definitive scientific opinion. He is an advocate and defender of ITER so naturally his opinion regarding alternative approaches should not be considered completely objective especially since money is involved. There are many mainstream physicists working on alternative fusion concepts (and I'm not talking about 'cold fusion' or it's derivatives at all). I'm sure they don't appreciate Cowley's attempt to limit funding and legitimacy of other approaches. Those approaches are not based on 'known flaws' but sound physics. In fact, in some ways, they already bested traditional approaches. The idea that there is one, and only one possible way to do fusion is flawed.
Speaking of ITER, when it was proposed, it was sold as a working testbed reactor which would lead directly to commercial reactors. Otherwise, the project wouldn't have been funded. Now, it's been noticeably downgraded to a mere 'historic' experiment to possibly lead to future improvements that might, in time, lead to a commercial reactor. So, it's bait and switch.
Definitive science is not based on scientists, but on what they publish in the scientific literature. JET has has published results, orders of magnitude better than anything else, include laser implosion at NIF. The currently ongoing alternative projects like Lockheed's have published nothing.
Yes they are. Cusps leak like a sieve, tried decades ago. Yes it's possible somebody might find a work around, but without a published approach that can critiqued its indifferent from (a physicist) jumping off a roof with a a claimed better garbage bag.
Publishing doesn't make facts more true and criticism isn't always necessary to make something work. Really, working fusion will more likely be done in the dark and announced as a surprise to the mainstream fusion community.
Frankly, this sounds like meaningless corporate-speak to me. You cannot schedule discovery/invention and you cannot design the post-discovery commercial development process until you know what you are developing.
I disagree with every one of those statements.
