Aloiz Burher
- Messages
- 2
- Reaction score
- 1
- TL;DR
- Can we interpret entanglement as a single, spatially extended energy body rather than two distinct particles?
Hi everyone,
I’ve been reflecting on the double-slit experiment and entanglement, and I have a question regarding the physical nature of the photon.
Instead of viewing entanglement as two distinct particles that communicate, is it mathematically or physically viable to treat the "entangled system" as a single, spatially extended excitation (an energy body) that has been stretched or deformed?
If we consider the photon as a non-divisible, extended structure (like a "V-shape" in space), wouldn't that resolve the paradox of superluminal signaling? In this model, acting on one "end" of the extended excitation would instantly affect the whole system simply because it's one unified object, not because a signal traveled between two points.
Furthermore, could "wavefunction collapse" be interpreted simply as a mechanical interaction where the detector hits this fragile, extended structure, forcing it to localize back into a point?
I'm curious to hear the mainstream perspective on why we don't treat the entangled photon as a single, physically "long" object instead of two "spooky" twins.
I’d like to offer an even more convenient analogy to clarify my point.
Imagine a U-shaped iron rod buried underground, with only its two ends sticking out of the surface.
In my view, 'quantum entanglement' might simply be our observation of an object whose true, extended structure remains hidden from us. In this model, the concept of 'signaling' disappears entirely — the sender and the recipient are the same whole. When one 'end' is affected, the status of the entire object is redefined instantly.
Thanks!
- The Illusion of Duality: To an observer who doesn't see the buried part, these look like two separate, independent objects (like a pair of entangled photons).
- Instantaneous Reaction: If you push or pull one end, the other end moves at the exact same moment.
- Unity of State: The second end doesn't move because it received a signal through space. It moves because it is part of the same physical entity.
Thanks!
