Can Epicyclic Gearing Operate with No Fixed Axis?
3 replies · 1K views
Cri85
The teacher said it is possible to use an epicyclic gearing with no axis fixed but nobody use the gearing like that. I watched this video:
at time 42s it's possible to watch it. I have 2 questions:
1) Is it possible to used the epicycloidal train with no axis fixed ?
2) If yes, what is the ratio of reduction ? is it dependent of the torque ?
Maybe if you have a link ?
I'm looking for this case, but each time the epicyclic gearing is used with one fixed axis.
I don't see an argument against it.
You have to consider all three rotations at the same time. Things like a ratio of reduction that consider only two do not make sense any more. That's probably the reason they are not used in that mode.
I can set the input to the sun gear and the output to the ring gear (planets are free to turn like they want) ? Why there is no a ratio ?
In this case, it's possible to reduce a rotational velocity without give a torque on the support ?
Then your output will not get any torque (neglecting friction). The free axis will rotate with the right speed to give zero output power.
