Can Flame Jets Effectively Constrain Plasma in Fusion Reactors?
  • Thread starter Thread starter Andrewtv848
    Confinement Jets
3 replies · 2K views
Andrewtv848
TL;DR
New type of active confinement
I have a idea for a plasma based fusion reactor. Using a combusting hydrogen/other reactant generate a flame jet to actively confine the plasma and possibly using a helium compressed jet stream as well to bring down turbulence.
My friend already says these will destroy the plasma but I am am not sure.
thanks for your time
Andrewtv848 said:
Summary:: New type of active confinement
Generally, any ion of Z>1, He, Li, . . . increases the energy losses from the plasma, in addition to having lower cross-sections (probability) for fusion reactions. In addition, as Z increases, there are a corresponding numbers of electrons which also contribute to the plasma pressure, without any benefit with respect to fusion.
Plasma pressure is of the order of 105 Pa. A good rocket engine can shoot out material at an optimistic ~5 km/s. For each square meter you need 105 Pa*1m2/(5 km/s) = 20 kg/s of material. ITER has a few hundred square meter surface area. Let's say 500 for simplicity. Then your jets shoot 10 tonnes of material into the plasma per second. The material is essentially at zero temperature compared to the plasma temperature. Heating 10 tonnes per second to 100 million K requires a power of a few petawatt - millions of gigawatts (for less than a gigawatt of electricity). At the given pressure you can only support maybe a few grams of material, so your system breaks down after a microsecond - time for the jets to move just a few millimeters. The system never reaches any sort of stable operation. The numbers just don't work out at all.
