Can FPGA/CPLD Replace PIC for Faster Laboratory Timers?
  • Thread starter Thread starter Abimbola1987
    Fpga Programming
The discussion revolves around the potential of using CPLDs (Complex Programmable Logic Devices) as alternatives to Microchip PICs for laboratory timer applications, focusing on timing resolution, toolchain usability, and the learning curve associated with FPGA/CPLD design. Participants explore various technical aspects, personal experiences, and alternative solutions.
  • One participant expresses dissatisfaction with the Quartus toolchain, citing unhelpful error messages and a challenging user interface.
  • Another participant questions the required timing resolution, suggesting that faster PICs may suffice for the user's needs.
  • Some participants propose using faster PICs, highlighting specific models that could meet the desired timing resolution of 5 ns.
  • Others argue that learning CPLD/FPGA design skills could be beneficial, as it allows for more complex functionalities beyond simple timing.
  • One participant mentions the TinyFPGA platform as a user-friendly alternative to traditional FPGAs, while another emphasizes the advantages of CPLDs over FPGAs in terms of features.
  • There is a discussion about the appropriateness of posting multiple threads regarding specific toolchain issues, with some participants suggesting that it would be acceptable.
  • One participant shares a positive experience with the Quartus software after overcoming initial installation challenges, indicating improvements in usability.
  • Another participant recommends FTDI modules as a viable alternative for applications requiring high data rates and flexibility without the need for an IDE.
Participants express a mix of opinions regarding the use of CPLDs versus faster PICs, with some advocating for the former due to their capabilities while others suggest that faster PICs could meet the user's requirements. The discussion remains unresolved on the best approach, with multiple competing views present.
Participants reference specific models and tools, but there is no consensus on the optimal solution for the user's needs. The discussion includes personal anecdotes and varying levels of familiarity with the tools mentioned.
This discussion may be of interest to individuals exploring alternatives to traditional microcontrollers for timing applications, those learning about CPLD/FPGA design, and users seeking advice on toolchain usability and troubleshooting.
Abimbola1987
Dear Sirs,
I'm using Microchip PIC's as programmable laboratory timer among other things, but the 100ns instruction cycles are not adequate anymore. So I thought of beefing it up with a 5M40Z MAX-V CPLD which has 5ns end-to-end delay, bought the programmer and downloaded the Quartus Prime Lite Edition software, and everything came to a grinding halt.
The Quartus toolchain is a piece of eclectic patchwork and it spews out un-googleable error messages with every click of the mouse. I'm not complaining about the Altera Hardware Description language (AHDL), it's the Integrated Development Environment (IDE) that's the culprit here.
Question: Can anyone suggest some alternatives? It has to be cheap and work out of the box?
Best regards
Abim
Abimbola1987 said:
Dear Sirs,
What timing resolution do you actually require?
P.S. I don't think PF users are required to be male.
Maybe start a separate thread with some of those errors you are seeing -- we might be able to help you get past them. I have used earlier versions of their toolchains.
BTW, are you using their "lite" version? http://fpgasoftware.intel.com/?edition=lite
I had chosen 5ns as acceptable, less is even better but then the price unfortunately goes up.
If you are referring to my use of "Dear Sirs" then firstly there is no specific gender requirement in that term, it is a civilized and colloquial greeting when addressing a predominantly male audience, which I believe PF is. As to political correctness I'm siding with Mr. Jordan Peterson.
If you believe that PF would not suffer from multiple threads about that topic, then I will try and install it again.
Yes, I used the Lite version.
Oh sorry, did I miss a thread already where you were asking for CPLD/FPGA help? Can you give ma a link?
no, I'm asking you if that would be acceptable for PF, I don't want to flood the forum with such commercial product specific questions.
I think it would be fine. You can post screenshots of what you are trying to do and what errors you are getting. I may download the lite version just to check it out...
Abimbola1987 said:
Dear Sirs,
Can you just use faster PICs?
The table at https://www.microchip.com/mymicrochip/filehandler.aspx?ddocname=en588853 lists 200 and 252 MHz 32-bit PICs with 4 x 32-bit counter/timers which should meet your 5 ns resolution requirement. Using a fast PIC with a familiar toolchain might offset using a part which is otherwise over-specified for your requirement.
I was. "Sir" is a specifically male greeting (unlike "Guys" - at least in some quarters). Whilst I agree that PF is likely to be predominantly male there's no need to unnecessarily discourage female (or, more generally, non-male) readers. (The make-up of the audience does vary across the various PF fora; there are more female screen names visible in the biology and teaching fora than here in EE.)
I think the OP is also trying to learn more about electronics in general, so picking up CPLD/FPGA design skills would be a plus. Hopefully the issues he is seeing with the toolchain are just basic user interface and conceptual issues.
Very culture dependent.
Yes I could use a faster chip and I did consider that, but then it would be useful only as a timer and not "among other things" e.g. burst read from ADC. With the CPLD I can evaluate a condition and set bit pattern on output all within 5ns, and that would be wonderful if I could do that for just €1 for the chip and €3 for the programmer.
I have also looked at https://tinyfpga.com/ which is sort of the Arduino of FPGA's with a community of users, but the CPLD won me over having more features than a FPGA.
I'm sorry if I didn't make my position clear on the subject of political correctness, please allow me to rephrase: I do not wish to discuss political correctness with anyone on the internet. if I had that desire, there are plenty of other fora where I would have ample opportunity to increase my blood pressure, PF is certainly not the right forum for such desires.
One fine day when I was meticulously soldering SMD logic gates to my SMD PIC, I realized that it was a complete waste of time and I had to expand my skill set with CPLD/FPGA design skills.
I will be reverting shortly with a new post as you suggested.
OK, so I managed to download and install the Quartus software, make a "Hello World" design and successfully compile it without errors, and that makes me Bob's nephew.
This time the software was available from the intel website, the download was painstakingly slow and cumbersome, but the install went without problems. First it wouldn't launch because of some shared libs missing, fixed that and Quartus popped up on my screen.
Found this hello world guide which I can recommend for first timers.
I noticed that Quartus had evolved to the better since last time I tried it, it's more intuitive and less clutter, so I expect plain sailing from here on. But I reserve my right to post questions when I eventually hit a snag.
Thank you.
Great news! :smile:
eq1 said:
I've found FTDI modules are great for these types of applications. You can get lots of pins, great data rates, and since the logic runs on the host, complex behaviors, all for little money (~$40). Just a USB port is needed and no IDE. And there is a ton of example code out there in a variety of programming languages.
https://www.ftdichip.com/Support/Documents/DataSheets/Modules/DS_FT2232H_Mini_Module.pdf
Thank you, I had a look at it, unfortunately it's too black-boxy for me, and it is Windows oriented, I'm using Linux.
They work on linux too. The biggest problem is that getting sub-ms timing over USB would be wildly optimistic if not downright impossible and that is way slower than you need.
FPGA/CPLD is probably the way to go as you have already found.
BoB
