Can I use back substitution to invert a matrix?
  • Context: Undergrad
  • Thread starter Thread starter NewStudent200
    Matrix
The discussion revolves around the use of back substitution to invert a triangular matrix derived from a system of equations with multiple variables. Participants explore the relationship between the derivatives of the equations and the inversion of the resulting matrix.
  • One participant describes a scenario involving n equations and n variables, leading to a matrix of derivatives dC/df, and questions whether finding df/dC equates to inverting this matrix.
  • Another participant confirms that inverting a triangular matrix is indeed possible and suggests that it is relatively straightforward.
  • A further inquiry is made about recommended algorithms for inverting a triangular matrix.
  • A participant responds that "back substitution" is the appropriate method and provides an example of how to derive the inverse of a triangular matrix, detailing the relationships between the elements of the original and inverse matrices.
Participants generally agree that back substitution is a suitable method for inverting a triangular matrix, but there is no consensus on specific algorithms beyond this method.
The discussion does not address potential limitations of back substitution or the conditions under which it may be applied, nor does it explore the implications of the triangular matrix structure on the inversion process.
NewStudent200
Hello all,
Say I had n equations, with n variables, so that
C1 = C1(f1), C1 is a funtion of f1 only
C2 = C2(f1, f2), C2 is a function of f1 and f2
Cn = Cn(f1, f2...fn), Cn is a function of all n vairables
I can calculate the matrix dC/ df where each line is the derivative of Ci with respect to the n vairables, The matrix will look something lile
a 0 0 0... 0
b c 0 0... 0
u v w x... z
Now if I was after the matrix df/dC then am I basically just trying to invert this matrix?
Thanks very much for any help
NewStudent200 said:
Hello all,
a 0 0 0... 0
b c 0 0... 0
u v w x... z
Yes, and, for a triangular matrix, that is fairly simple.
Great. Thanks very much. Is there a particular algorithm that is recommended for a triangular matrix?
Regards,
Just "back substitution". If your matrix is, say,
[tex]\begin{bmatrix}a & 0 & 0 \\ b & c & 0\\ d & e & f\end{bmatrix}[/tex]
then its inverse will be a matrix of the form
[tex]\begin{bmatrix}u & 0 & 0 \\ v & w & 0\\ x & y & z\end{bmatrix}[/tex]
such that
[tex]\begin{bmatrix}a & 0 & 0 \\ b & c & 0\\ d & e & f\end{bmatrix}\begin{bmatrix}u & 0 & 0 \\ v & w & 0\\ x & y & z\end{bmatrix}= \begin{bmatrix}1 & 0 & 0 \\0 & 1 & 0\\ 0 & 0 & 1\end{bmatrix}[/tex]
You must have au= 1 so u= 1/a. Then bu+ cv= b/a+ cv= 0 so v= -b/ac. cw= 1 so w= 1/c, etc.
  • · Replies 25 ·
15K
