Can mass go faster than the speed of light?
63 replies · 11K views
matheinste said:
Hello all
To clarify a point for myself I have paraphrased the original question in an attempt to remove the necessity of some of the additional and interesting material in the answers.
Given two separate points in space, if a massive object and a photon start from the first point at the same time as each other, is there any condition under which the massive object could arrive at the second point before the photon arrives. I am of course assuming that they can follow the same path. If the same path is not possible in GR then can we restrict the answer to SR in which I believe the same path can be followed.
Matheinste.
In GR a massive particle can not always follow the path taken by a photon. In the example of a photon orbiting a black hole as mentioned by JesseM it is not possible for a massive particle to follow the photon orbit path. What can be fairly safely stated is that if you find the fastest possible path for a photon between two given points then the minimum time for a massive particle to move between those two points by any path will always be longer. Stated in the logical reverse the minimum time for a massive particle to move from one point to another will always be longer than the minimum time taken by a photon when the massive particle and the photon taken the shortest route available to them. This is always true in a vacuum but an important exception is that in some mediums, photons can be slowed down sufficiently that they actually move slower than some massive massive particles in the same medium.
Count Iblis said:
It is interesting to consider tunneling. Suppose a clock on the North Pole tunnels to the South Pole. What will be the proper time that will have elapsed?
Here's a https://www.physicsforums.com/showpost.php?p=1543402&postcount=8" that compares a clock on the surface at the equator to a clock at the centre of the Earth. The rotation of the clock at the equator with the Earth and the differing gravitational potentials are both taken into account.
I also have done the calculation for the scenario you propose, as well as for one complete cycle, i.e., the clock falls from the north pole to the south pole, stops, turns around, and falls back to the north pole. I have compared the elapsed time on the falling clock to the elapsed time on a clock that stays at the north pole, and to elapse time on a clock at the centre between meetings. This requires some somewhat subtle numerical integration. I would have to dig to find these results, and I don't think I've posted any of the results.
Thanks kev and JesseM you have fully answered my question. The SR question i was sure of but some of the other answers in this thread seemed to complicate matters. The GR case is along the lines i thought it would be because of a photon and a massive particle not being able to follow the same path in the presence of gravity.
Matheinste.
By "path", I assume you mean the spatial path rather than the path through spacetime? In this case, a massive object moving on a freefall geodesic may not be able to follow the photon orbit path, but a rocket that's not in freefall could in principle (just as a rocket can maintain a constant radius from a black hole at any distance above the horizon).
Yeah, that's what I was saying, it's always possible to find a photon that reaches the destination faster than the massive object, even though there may be other examples of photon paths that take longer to get to the destination (like taking the long way around a black hole vs. taking the shortest path).
