Mentor
- 37,557
- 14,432
It's getting difficult to disentangle the different cuts. What do we have so far:
* The upper left corner is the largest element on the diagonals (excluding the center, but if the center is 13 it's trivially true for that as well). This covers rotation and the corner-connector symmetry
* The upper right corner is larger than the lower left corner. This covers mirrored cases.
* The upper left connector is larger than the lower right connector. This covers the 2/4 exchange symmetry.
If we apply the 1<->25 swap to a solution then we have to rearrange everything to fit that pattern again. We would need an inequality that's guaranteed to swap.
Here is an approach that separates the symmetries better:
* The sum of the corners needs to be larger than the sum of the connectors (can they be equal? That would need to be treated separately). This covers only the corner-connector symmetry.
* The upper left corner is the largest corner
If we apply the 1-25 swap then the first condition gets reversed, so clearly we need to do the corner/connector swap. In general we might have to rotate and mirror the magic square, and it's possible that we need to use the 2/4 exchange.
I didn't find a nice way to throw away 1/2 of the magic squares, but I found a classification: Consider the center row/column. If the sum of the outer numbers is larger than the sum of the inner numbers, then this is still true after the 1-25 swap and applying the corner/connector symmetry. This splits our sample of magic squares (with 13 in the center) into two groups. Maybe one of the groups is empty, or has some nice patterns?
