Can one photon trigger two detectors at both slits?
  • Level: Graduate
  • Thread starter Stavros
6 replies · 385 views · last reply
Stavros
Can two independent, non-destructive detectors each record the same single photon at a different slit in every run, while the photon reaches the screen and interference remains?
I would like to understand whether quantum mechanics, and specifically quantum electrodynamics (QED), permits the following experiment.
Proposed setup
Consider an ideal, symmetric double-slit experiment in which photons are emitted one at a time.
Place two separate, spatially localized, independent detectors at the two slits:
Detector A is located at slit A. Detector B is located at slit B.
The requirement is that both detectors produce a distinct, unambiguous, independently recorded detection event during every individual photon run.
In other words, for each single photon, detector A must register an event and detector B must also register an event. Both records must correspond to the interaction of that same photon with the two spatially separated slit regions.
The detectors must be non-destructive: the photon must survive both interactions and continue to a photographic screen behind the slits.
After many repetitions, the screen should still build up the ordinary double-slit interference pattern.
What I am specifically asking
I am not referring to weak traces, weak pointer shifts, or small statistical signals reconstructed from an ensemble of photons. I am asking whether two actual, distinguishable detector records can be produced in every individual run.
Nor am I requiring the detectors to avoid recording a local interaction. On the contrary, the central requirement is that each detector should produce a genuine record of an interaction at its respective slit.
I understand that ordinary which-path measurements generally destroy interference. However, I would like to know whether that familiar result establishes a general impossibility for the more specific arrangement described here, or whether a suitable non-destructive interaction could behave differently.
Questions
Does quantum mechanics, and more specifically QED, permit such an arrangement? If it is possible, can an explicit physical model or interaction Hamiltonian describe how both detectors register the same photon in every run while the photon survives and interference is retained? If it is impossible, is there a rigorous theoretical proof identifying the precise physical constraint that prevents it? Has this exact arrangement already been studied, either theoretically or experimentally?
I am aware of the 2023 paper Unambiguous joint detection of spatially separated properties of a single photon in the two arms of an interferometer. However, I am interested in the stronger requirement of two actual, independent detector records in every individual run, rather than weak-measurement signals obtained statistically over many runs.
I am asking about the physical possibility and its theoretical constraints, not about a particular interpretation of quantum mechanics.
No, this will never happen.
Please give a link.
Please give a link.
Here is the paper:
S. N. Sahoo et al., “Unambiguous joint detection of spatially separated properties of a single photon in the two arms of an interferometer,” Communications Physics 6, 203 (2023).
https://www.nature.com/articles/s42005-023-01317-7
The experiment demonstrates simultaneous weak measurements of two different photon observables in spatially separated arms of a Mach–Zehnder interferometer, using weakly coupled pointers and post-selection.
My question concerns a stronger requirement: two independent detectors, one at each slit, each producing an actual, distinct, unambiguous detection record for the same photon in every individual run, while the photon survives and interference remains.
I understand that the paper does not demonstrate this stronger arrangement. I cited it because it is closely related to the question of jointly detecting properties of a single photon in spatially separated regions.
The term single photon is misleading, it is properties of a single photon..
When a measurement is made then it's state is getting disturbed but you could try to weaking that or use an indirect method.
There are actually two photons involved but more importantly the single photon cannot be considered
a free particle. It is in interaction with the detectors and other devices.
In the end it is in principle impossible to tell if the photon that is getting detected is still the same one as the one that had left the beam splitter.
Yes, and the answer is no, your "stronger requirement" will never happen. For one photon emission you will never get more than one photon detection under the conditions you describe.
No measurement is made at the beam splitter, not even a weak measurement, so "the one that had left the beam splitter" is not even a meaningful concept to begin with.
