Can sinx/x be integrated using integration by parts?
  • Level: Graduate
  • Thread starter Thread starter gatorules
    Integration
7 replies · 28K views · last reply
gatorules
Wherever I look on the internet it says that sinx/x cannot be integrated by elementary techniques, but it seems that there is a method using integration by parts of the quotient rule. However, when I compute definite integrals with this, the answer that my calculator returns is different than the answer I get with the definite integral. Can anyone tell me where my problem is or if my method does actually work.
[tex]\frac{d}{dx}\frac{f(x)}{g(x)} = \frac{f'(x)g(x)-g'(x)f(x)}{g^2(x)}[/tex]
[tex]\frac{f(x)}{g(x)}=\int \frac{f'(x)g(x)}{g^2(x)}\,dx-\int \frac{g'(x)f(x)}{g^2(x)}\,dx[/tex]
[tex]\int \frac{g'(x)f(x)}{g^2(x)}\,dx=\int \frac{f'(x)}{g(x)}\,dx-\frac{f(x)}{g(x)}\,dx[/tex]
[tex]\int \frac{sin(x)}{x}\,dx=\int \frac{xsin(x)}{x^2}\,dx=\frac{1}{2}\int \frac{2xsin(x)}{x^2}\,dx[/tex]
[tex]g(x)=x^2[/tex]
[tex]f(x)=sin(x)[/tex]
[tex]g'(x)=2x[/tex]
[tex]f'(x)=cos(x)[/tex]
[tex]\frac{1}{2}\int \frac{2xsin(x)}{x^2}\,dx=\frac{1}{2}\int \frac{cos(x)}{x}\,dx-\frac{sin(x)}{x}\,dx[/tex]
[tex]\int \frac{cos(x)}{x}\,dx=\frac{1}{2}\int \frac{2xcos(x)}{x^2}\,dx[/tex]
[tex]\frac{1}{2}\int \frac{2xcos(x)}{x^2}\,dx=\frac{1}{2}\int \frac{-sin(x)}{x}\,dx-\frac{1}{2}\frac{cos(x)}{x}\,dx[/tex]
[tex]\int \frac{sin(x)}{x}\,dx=\frac{1}{2}\left(\frac{1}{2} \int \frac{-sin(x)}{x} \,dx - \frac{1}{2}\frac{cos(x)}{x}\right)-\frac{1}{2}\frac{sin(x)}{x}[/tex]
[tex]\frac{5}{4}\int \frac{sin(x)}{x}\,dx=-\frac{1}{4}\frac{cos(x)}{x}-\frac{1}{2}\frac{sin(x)}{x}[/tex]
[tex]\int \frac{sin(x)}{x}\,dx=-\frac{1}{5}\frac{cos(x)}{x}-\frac{2}{5}\frac{sin(x)}{x}[/tex]
I got a bit of a headache following you since there are extra dx's everywhere & at least one is missing ...
But, could you check your result against a power series expansion of
sin(x)/x = 1 - x^2/3! + x^4/5! - ...
Integral sin(x)/x = x - x^3/3(3!) + x^5/5(5!) - ...
and compare that with the series for your answer?
I haven't looked at your method yet, but there's an easy way to tell if your method works. Take the derivative of your answer and see if you get sin(x)/x
your mistake is that you took [itex]g(x) = x^{2}[/itex], whereas, according to the formula you derived the denominator is [itex]g^{2}(x)[/itex] and should be equal to [itex]x^{2}[/itex], thus [itex]g(x) = x[/itex]. But, then, [itex]g'(x) = 1[/itex] and not [itex]2 x[/itex] as you had assumed.
Thanks. I guess that means the method is totally trashed by that explains why it wasn't working.
Yes.
Alternatively, you could have used the ordinary integration by parts:
[tex] \int{\frac{\sin{x}}{x} \, dx} = -\int{\frac{1}{x} \, d(\cos{x})} = -\frac{\cos{x}}{x} - \int{\frac{\cos{x}}{x^{2}} \, dx} = -\frac{\cos{x}}{x} - \int{\frac{1}{x^{2}} \, d(\sin{x})} = -\frac{\cos{x}}{x} - \frac{\sin{x}}{x^{2}} - 2 \int{\frac{\sin{x}}{x^{3}} \, dx}[/tex]
You may notice a recursion for the integrals:
[tex] I_{n} \equiv \int{\frac{\sin{x}}{x^{2 n + 1}} \, dx}[/tex]
By similar double integration by parts, you get:
[tex] I_{n} = -\frac{\cos{x}}{x^{2 n + 1}} - \frac{(2 n + 1) \sin{x}}{x^{2 n + 2}} - (2 n + 1) (2 n + 2) I_{n + 1}[/tex]
As you can see, this procedure goes on indefinitely and you do not get a closed form.
