Can someoen verify i did this differentiation right?
  • Thread starter Thread starter mr_coffee
    Differentiation
10 replies · 3K views · last reply
mr_coffee
Hello everyone, these problems take like 2 pages to do so i don't want to redo it all if i messed up on a derivative, can someone tell me if they get the same thing for y''?
http://img220.imageshack.us/img220/8417/lastscan2rf.jpg
I think I better do these problems in pencil...:bugeye:
y'' is the correct derivative from y'.
But where did y' come from?
What is y?
Is y that first line on the page, with the number 2 written after it (in a circle).
If so, then your y' should have used the product rule like y'' did.
Thanks for the responce Fermat, here is what y is:
http://img100.imageshack.us/img100/1671/lastscan2vi.jpg
So your thinking I did it wrong?
You got the y' wrong. I'm afraid.
y = u1.f(t) + u2.g(t)
you should have, (using the product rule)
y' = u1'.f(t) + u1.f'(t)+ u2'.g(t) + u2.g'(t)
where f(t) = e^(-7t)
and g(t) = t.e^(-7t)
to get g', you have to use the product rule on g(t).
Also, I don't see hoe you got the line marked (2), from the line above it.
HOLD ON. more to come.
I just noticed. You got a repeated root.
With repeated roots, the solution is,
y = (A + Bt)e^(rt)
where r is the repeated root.
Also, c1 and c1 are supposed to be constants of integration. Why did you replace them with functions ot time c1 = u1(t) ??
I guess this must be just exercise in the use of variation of parameters and wronskians - yes ?
It's a lot easier to do it the usual way.
y1 = (A + Bt) e^(-7t), but you've got that haven't you.
and y2 comes out quite simply at,
y2 = 5e^t
so,
y = y1 + y2
y = (A + Bt)e^(-7t) + 5e^t
(takes about half a page)
Mind you. I've not done variation of parameters or wronskians, so I hope I'm not misleading you.
Actually I'm not forced to use variation of paramters, i thought that was the only way to solve this problem because it its not homogenous!
I understand hwo You found y1, but how did u come out with y2 = 5e^t?
WOw that was right and took like no work at all, if you can explain to me how you found y2 i will eat this cupcake infront of me.
http://cwcsrv11.cwc.psu.edu/webwork2_files/tmp/equations/df/993c2e2165f062929af57210607b441.png
finding y2 is just "standard procedure"
If the "non-homogeneous" function is say,
f(x) = a polynomial e.g f(x) = 2x² + 3x - 1, then try y2= Ax² + Bx + C
if f(x) is a trig function e.g. f(x) = sin(3x), then try y2 = Asin(3x) + Bcos(3x)
if f(x) is an exponential e.g. f(x) = 5e^(-3x), then try y2 = Ae^(-3x)
that sort of thing.
Whatever the function f(x) is, try a similar function for y2.
p.s. this standard procedue doesn't always work. Try it on y'' + 25y = 50sin(5t).
hm...I c, but on the right hand size of the equation it was 320e^t
r^2+14r+49 = 320e^t,
so how did u figure 5 as being the coefficient that will work?
I would try y2 = Ae^(t) right? because its 320e^t?
