Can someone clarify this please? Confusing Wording
  • Thread starter Thread starter PhysicsOPhun
    Confusing
The discussion revolves around a physics problem involving two blocks colliding with a spring bumper. Block 1, initially moving at 1.2 m/s, collides with block 2, which is at rest, leading to maximum spring compression when both blocks move at 0.6 m/s. Participants seek clarification on whether "v/2" indicates both blocks traveling at 0.6 m/s and how to derive the spring's force constant from the given maximum compression of 1.9 cm. The importance of using conservation laws, particularly momentum and energy, is emphasized to solve the problem effectively. The conversation highlights the need for clear understanding and application of physics principles in collision scenarios.
PhysicsOPhun
Can someone clarify this please? Confusing Wording...
1.Two blocks, each with a mass 0.40 {\rm kg}, can slide without friction on a horizontal surface. Initially, block 1 is in motion with a speed v = 1.2 {\rm m/s}; block 2 is at rest. When block 1 collides with block 2, a spring bumper on block 1 is compressed. Maximum compression of the spring occurs when the two blocks move with the same speed, v/2 = 0.60 {\rm m/s}.
2.If the maximum compression of the spring is 1.9 {\rm cm}, what is its force constant?
3. Hi everyone, All I really need is clarification of the last given. It says "...blocks...move with the same speed, v/2 = 0.60 m/s"
V/2 ? Does this just mean they are both now traveling .60m/s or is there something else I can derive from this that I am missing.
Thanks!
The actual value you would have to work out, but you can see that if the second block moves faster then the spring loses ground, and if block 2 moves slower then block 1 will push block 2 such that the springs restorative force and all that forces the two into the same speed.
I'm sorry...I just don't follow. If block 2 moves slower (stopped) then block 1, block 1 will push block 2 so that the springs (restorative force?...is that like potential energy?).
The way I'm brainstorming it is that say, without the springs the block would have to be moving at a velocity twice that of the 2nd block's potential energy so that they could ultimately move at the same velocity.
The spring, must also be significantly weaker to absorb the collision and keep both blocks moving.
Anyway, I feel like I know exactly what to do...if anyone could offer advice that would be nice but what I really want to do is finish it up right now and post it to verify it.
Thanks Mindscape for the quick reply...
Yes, I think that as you work it out it will start to make sense. Look out for units!
I Really hope someone is up and dying to do some physics problems!
Hi guys, I'm the original poster...
I'm pretty much just staring at the problem and have been for quite some time...Can someone private message me or e-mail or reply here and help me out with some details...I'm going in circles and really don't want to give up. It's been HOURS!
thanks
use conservation laws
Maximum compression of the spring occurs when the two blocks move with the same speed, v/2 = 0.60 {\rm m/s}.[/b]
Use conservation laws whenever you can.
In this case, the first step is to use conservation of momentum: the blocks are identical, and they're moving in only one dimension, so we know that the total speed will be constant.
The total speed initially is v + 0 = v.
Later, it's v/2 + v/2 = v.
(Don't bother to work out why - the question has saved you the trouble of doing that by telling you the speeds - I guess this question is mainly to test your knowledge of springs, so the other bits of the question are made as easy as possible for you - sometimes examiners are nice guys!)
The next step is to use conservation of energy - the total energy of the blocks is less than it was - where has the extra energy gone, and how much is it - that should tell you all you need to know about the spring!
I hope this has put a spring in your steps! :smile:
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
