Can someone explain the 4-force to me.
  • Context: Graduate
  • Thread starter Thread starter ozone
    Explain
The discussion centers on the concept of the four-force in the context of relativity, specifically referencing James Hartle's "Intro to Relativity." The four-force is defined as f = (γF·V, γF), where γ is the Lorentz factor, and F is the standard three-vector force. The forum participant expresses confusion regarding the utility of the fourth component of the four-force, which represents the time aspect and relates to power. The conversation highlights the challenges of converting between three-vectors and four-vectors in relativistic physics.
  • Understanding of four-vectors in physics
  • Familiarity with Lorentz transformations
  • Basic knowledge of momentum and energy in relativistic contexts
  • Concept of the Lorentz factor (γ)
  • Study the derivation and applications of the energy-momentum four-vector
  • Learn about the physical significance of the time component in four-forces
  • Explore the relationship between power and force in relativistic mechanics
  • Review conversion techniques between three-vectors and four-vectors
Students and professionals in physics, particularly those studying relativity, as well as educators seeking to clarify the concept of four-forces and their applications in relativistic scenarios.
ozone
I understand that we can write the 4-force in terms of the vector force based on velocity, and the energy of the system in general.
What I don't understand is what this gains for us, and why we use it. Also correct me if I am incorrect in my definition above.. I don't have my book infront of me.
Knowing dp/d\tau = f isn't useful?
no that's very useful. I don't understand though why we have a vector we call the energy-momentum four-vector,
defined as
p = (E, p)
Where the vector p is just our ordinary momentum.
Also we have a 4-vector force defined as
f = (\gamma F \cdot V, \gamma \text{ }F)
Obviously both terms contain standard 3-vector, but I'm not sure what physical good the fourth piece is.
This is out of James Hartle's Intro to relativity.
I'm not sure I understand what "fourth" piece you're referring to.
At any rate, I find the formulas for converting between ordinary force and four-force (and the same for acceleration) to be very annoying and tedious. I personally try to avoid dealing in ordinary force and acceleration precisely for this reason. It's just much easier to deal only with four-vectors or only with three-vectors and not constantly convert back and forth between them.
The fourth piece (the time piece) is just confusing to me.. I understand having momentum in terms of velocity but my book doesn't really explain why/what the 4th piece of the vector is.
Also I solved a relativistic energy conservation problem (in the lab frame) and I am pretty sure I only needed to use the 3-vector but I want to make sure that I did that correctly.
The time component of the four-force is basically the power the force applies to the object in question.
  • · Replies 53 ·
  • · Replies 47 ·
  • · Replies 35 ·
  • · Replies 38 ·
  • · Replies 38 ·
