Can the AM-GM Inequality be Used to Solve this Problem?
  • Thread starter Thread starter hsong9
    Inequality
The discussion revolves around proving an inequality involving positive real numbers and their powers, specifically comparing the fifth and fourth roots of averages of these powers. The problem is situated within the context of inequalities, particularly the AM-GM inequality and Jensen's inequality.
  • Participants explore various approaches, including taking logarithms, applying Jensen's inequality, and considering convex functions. There are discussions about the validity of these methods and hints are provided regarding the manipulation of variables and functions.
Participants are actively engaging with the problem, offering hints and suggestions for potential approaches. Some express uncertainty about the application of Jensen's inequality, while others confirm the convexity of certain functions. There is a mix of ideas being explored without a clear consensus on the best method yet.
Some participants note the challenge of proving the inequality without using logarithms and question the assumptions underlying their approaches. The discussion reflects a collaborative effort to navigate the complexities of the problem.
hsong9
Let X1,X2,...,Xn be positive real numbers. Show that
((x15+...+xn5 )/ n)1/5 >= ((x14+...+xn4 )/ n)1/4
I have tried by taking logarithms. Is it right approach?
Or.. It can be applied to AM-GM-HM inequality?
how?
how?
I think you can prove it using Jensen's inequality, if you know it.
I know Jensen's inequality, but I am not sure how it will work for my question.
Can you give me some hints?
Thanks
Thanks
OK, one form of Jensen's inequality is
\phi\left(\frac{\sum y_i}{n}\right) \leq \frac{\sum \phi(y_i)}{n}
which is true provided that \phi is a convex function.
Hint: let
y_i = x_i^4.
Then what convex function \phi would work? Hint: You need something that will change powers of 4 into powers of 5.
You could raise both sides to the 20th power and expand? Your first step however would be to factor out the n's. They should disappear.
Try maybe some variable substitutions? x_k = y_k^p for some strategically chose value of p
(I'm guessing here so my suggestions may not be helpful. But I don't think the logarithms will be helpful due to the sums inside.)
Thanks for your hints, but I am not sure yet.
If I have x^4 = y and x^5 = y^(5/4), then
I get the inequality which is just the same with the problem.
how do I get the inequality of Jensen? (without logarithms?)
Thanks
Thanks
I'm not sure that I understand your question. Let
y_i = x_i^4
Now what \phi did you choose? If you choose the right one, then after a little algebraic manipulation you can prove that your inequality is true. I just worked it out here at my desk; it took 4 lines.
If you are asking how to prove Jensen's inequality, the finite case is easy (yet very clever) and can be found under the heading "Proof 1 (finite form)" here:
http://en.wikipedia.org/wiki/Jensen's_inequality
You mean I have to make some convex function
and then apply into the inequality.
Finally, I will get the answer. Right?
hmm, If so, I will think about the function.
I think f(x) = x^(5/4) is fine as your hint.
And also f(x) is convex as condition of x_{i} --> positive real numbers.
Right?
Right?
Yes, that's correct. (In fact, x^(5/4) isn't even defined for negative x, unless you allow it to take on imaginary values.)
Thanks
I was thinking more along the lines x = y^(5/4) or x = y^(4/5). Substitute then apply an appropriate power to both sides of the equation and you should get the Jensen form.
I got the answer.
It's only 4-5lines.
Thanks!
