Can water spray clean carbon from a running engine intake?
  • Topic: Automotive
  • Thread starter Thread starter zoobyshoe
    Engine Water
69 replies · 148K views
zoobyshoe
I ran across several YouTubes that claim, and apparently demonstrate, that you can clean carbon deposits from a car engine by simply spraying or pouring (very slowly) water into the intake when the engine is fully warmed and running.
I've never heard this from a reliable source and my reaction is that it is probably an urban legend, like removing rust with coca cola and aluminum foil. However, Eric The Car Guy, in the last video, is usually mainstream, so I'm not sure.
The principle is alleged to be that, upon hitting the hot piston, the water flashes to steam and dislodges the carbon deposits. And in the second video it asserts the idea for this came from examination of engines whose head gaskets had failed: the pistons onto which coolant had leaked were weirdly clean while the protected pistons were encrusted with carbon.
What is the real story on this?
One would expect anecdotes from the use of water injection in aircraft engines to predate this. Sounds plausible. Probably want to plan on a couple of short running time oil changes after doing this sort of thing.
That's something I wondered about. Proponents mention that water injection is a tried and true technique for achieving other goals. Therefore, I read the Wiki article on water injection but it made no mention of engines employing it being especially free of carbon. Do you know if it's maintained they are?
zoobyshoe said:
free of carbon
Don't recall seeing such claims re. aircraft use --- doesn't mean it's not been mentioned. Do have vague recollections that pilots were asked to avoid use of water injection unless it was necessary/prudent given circumstances they were in --- does that imply it was rough on engines, or just a "save it until you really need it" recommendation?
No myth was common practice.
Steam has nothing to do with it. Water injection was used to prevent Detonation at high RPM before all this computer controlled ignition stuff came along. Had side effect of cleaner combustion chambers i guess..i never played with it but know its design purpose.
We always used ATF ( Automatic Transmission Fluid).
Was common practice when engines had carburetors. Oil is not compressible (neither is water but will rust things). The idea was to introduce fluid into the combustion chamber and knock off the carbon deposit build up. The oil would burn off and foul the spark plug but it was being replaced anyway so did not matter. This helped a lot with the cars owned by the little old ladies who never got the engine to full operating temperature going to the local grocery. Those engines were a mess to rebuild. The intake manifold heat risers were always clogged up with carbon. Anyone who has done this knows carbon requires a hammer and chisel to remove. When you use ATF at high idle speed you are essentially beating he-- out of the carbon deposits and everything else in the combustion chamber.
btw - you get blown head gasket when you have very hi compression ratios ( not likely today) or have cast iron engine block and aluminum cylinder head. Eventually the result of differing thermal expansion rates will cause a leak to the water jacket passages. This usually happens around 85,000 miles of a cheap iron / al engines life span. Then you have to pull the head and replace the gasket. And to do it right, mill the head surface flat as it is probably warped. ( this is the typical scenario these days with little cast iron 4 cylinder blocks and aluminum heads)
Sprint cars run on alcohol that has a small amount of disolved water. The engines are spotless, you can't even read the plugs.
I will give you that. :cool: Methanol is hygroscopic which means it will absorb water vapor directly from the atmosphere. So you are going to have absorbed water diluting the fuel value of the methanol .But it helps suppresses engine knock. You have to watch your fuel cans real close. Containers of methanol fuels must be kept tightly sealed. It burns " cleaner" than racing gas and with the added water so you would expect clean piston domes etc...
I hate the stuff mainly because you can not see it burn..one time as a kid i was at the pit gate when a sprint car raced into the pits at 35 mph and slammed on the brakes. The driver leaped out of the car. A crew man "hosed" him down with a fire extinguisher...he was on fire..i never would have known..
The ethanol that is put in our fuel is problematic, for one it's of poor quality and secondly it attracts moisture. Not good for metal gas tanks or fuel lines . You have a difficult time starting any machinery that isn't used all the time.
I have read about this as being a beneficial side effect of using water injection on an engine. AEM makes a water only injection kit and I think they mention that it can keep cylinders and valves clean. It makes sense, don't some shops remove the head and intake and clean them with steam? I wouldn't use tap water though I would use distilled water only, tap water could leave deposits of its own.
My VW TDI users forum had many stories of hydrolocking diesel compression ignition engines with Sea Foam brand.
In the UK there was a craze for steam injection in about 1970. The vehicle had a gallon container of water in the engine compartment, and a copper tube went from this and passed across the exhaust pipe. The resulting steam was led into the air filter box. It was supposed to raise the octane rating of the fuel and I understand that it did work.
I had a '65 corvair turbo in 1985 , you couldn't get leaded fuel , so I opted for a holley wat er injection unit . With very few sensors , it injected (sprayed) water at higher vacuum and solved my detonation problem beautifully.
After mowing my whole lawn and mulching a bunch of leaves my mower was nice and hot. It's a Kawasaki 10 Hp engine, i pulled off the air intake cover and pushed the throttle up to about 2/3 power, i then slowly dropped distilled water in, it sucked in the water, the rpm would drop a little and make a popping noise, i did this about 15 times using only a small amount of water each time. The engine definitely idles better and ill see how it performs next time i take it out. I think this is a great trick that costs practically nothing and is very easy to do, i would recommend it. I am trying to find a way to do it to my VW 2.0L Turbo, just got to get a hole in the intake manifold tube.
I wonder if the carbon might cause problems down stream by getting lodged in cat converter .
Thats a good question, maybe it would be wise to disconnect it before you did this trick. On my mower engine i don't think there's any cat to worry about, only a small exhaust.
Valves get carbon build up that hinders air flow, reducing performance . Regular decarbonizing might be a smart thing to do.
Here is a very mildly educated guess at what might happen re water cleaning carbon in an engine.
Steam reacts with carbon to form synthesis gas, this is part of the process to produce feedstock for a Fischer–Tropsch plant. It might be that the fine mist of water turns to steam on contact with the hot internal parts of the engine and that steam then reacts with the available carbon.
Pouring water, out of a cup, jug or hose into an engine is probably not the best way to try test this process.
Just by way of trivia, the 1962 Oldsmobile F85 was delivered with the Fluid-Injection Jetfire engine that was turbocharged. Oldsmobile referred to the water/alcohol mixture as 'Turbo-Rocket Fluid' that was used as a detonation suppressor. I don't know if the engines were any cleaner though.
I have seen how clean a combustion chamber is when a head gasket fails between a coolant channel and cylinder. I have no doubt that water can clean carbon deposits.
I don't know if 5 minutes with a plant sprayer does the same job or not though. E.g.
Carbon build up might raise compression and even a small build up at the valve base hinders air flow . Seems like these two might cancel each other . I'm getting fascinated by fuel vaporization , let me know if you have any insight .
Water does a nice job decarboning the piston/cylinder area but has virtually no effect on the intake side of the intake valve or EGR passages and that is where the majority of carbon build up happens. This is much more of a problem in direct injection engines. The PCV system functions to recycle combustion blow-by through the intake. It builds up on the intake valve where the venture effect causes low pressure and the combustion contaminants condense out and adhere to the valve head. This requires chemical or mechanical removal and can not be removed with water. You can decarbon part of your engine with water, but you are treating the part of the engine least affected by carbon buildup.
Is there some reason why this craze passed? Or do you have any more information regarding this practice?
I think you're on the right track here, though there's likely a different process involved, and carbon deposits may be peripheral to the reaction(s) of interest. Assuming you're talking about the H2O + CO water shift reaction (which subsequently feeds the main reaction of (2n + 1)H2 + nCO -> alkane + H2O), that relies on carbon monoxide rather than raw carbon which is presumably the major component of carbon deposits on engine parts. There's plenty of CO to go around post-combustion in most real-world Otto cycle engines (for example), but there's usually more CO2. Increasing the amount of water present during and immediately after combustion may also have an effect on the water's equilibrium state, depending on the temperature and pressure inside the cylinder.
I suspect steam injection works to increase octane rating by cooling the charge. In 1970, many cars required high octane fuel, which was expensive, and steam injection allowed the use of cheaper low octane fuel. In the end, people were too lazy to top up the water container. As today's engines have fuel injection under computer control, the idea of steam injection is not so easily applied. I think some aero engines used water injection.
I'm not sure steam injection would do much good by cooling the fuel/air charge. The tube picking up heat from the exhaust in the units you cited from cars in the early 70s implies that they wanted to increase the temperature of the injected steam. Were it used primarily as a cooling agent, you'd want the lowest water temperature you could get without hydrolocking the engine, which is usually why misting is done in water injection/antiknock systems.
I think, instead, the steam injection served as a chemical version of an F1 ERS system.
If too much water is added, the drops will hit the piston and crack them or break the rods. Be careful!
I know that at least here in Australia in the 80's and 90's you could buy after market 'water injection' kits for cars, the argument then was the same thing, it removed carbon buildup on the pistons.
The story behind it was from WW2 when the US was using jeeps in the tropics, they found that when they pulled the engines down they were very clean. I don't know if they are still available though.
First question is, which part of the engine this method substantially cleaned from carbon residue? As far as we know, the cylinder is almost fully retracted with the piston in it, aside from the exhaust manifold and exhaust pipe.
For engine using light fuel (petrol or gasoline) is most unlikely to have carbon deposit problem since, gaseous fuel readily combust with air, unlike viscous diesel.
Lubricant carbon deposit in lower part of the engine perhaps has consequent effect due to engine heat, in which by the piston ring and seal, water will not be able to access in there. And if ever water goes down to the bottom, the problem is it accumulates there.
Water in lubricant is undesirable, because consequently the 2 will form organic acid later on and acid as we know it, corrode metals.
Water in minimal portion in diesel combustion is good in atomisation of fuel. Since, water and fuel does not mix/emulsify. Tiny spherical droplets of water, will allow the fuel to stick on outer surface by density, thus increasing the area of contact with air in combustion, but some of the energy of the fuel burned is going to be used up converting water to steam, consequently reducing engine output as a result.
To your query, I would say, this is a Myth.
Absolutely. That's why it's so dangerous to mess around with water injection. Well dangerous to the engine anyway . . .
All these methods you guys descibed above are not good for engines. I saw few weeks ago new machine called Oxyhydrogen carbon cleaning machine, delivered by Avitus Corporation from USA.The principle of this cleaning machine is by electrolyzing water into Hydrogen and Oxygen gas and then suck this gas mixture into the engine by air intake.
Due to the high temperature of burning of this gas mixture and fuel ,cleaning the accumulated carbon deposition in the engine.
How I know this machine is already in use with all big brands like BMW,Mercedes,Honda..
The modern version of this is "water-methanol injection," it is used in tuned forced induction applications (like aftermarket turbochargers or superchargers) to help reduce the intake charge by vaporizing the water. Water absorbs a lot of energy when it transitions from liquid to gas, and this reduced temperature of the charge can help reduce pre-igntion and detonation when the intake charge is highly compressed out of a turbocharger). This kind of system is especially used when an inter-cooler is either unavailable or unable to fully cool the charge for the application.
See here: http://www.dieselarmy.com/engine-tech/how-it-works/how-it-works-water-methanol-injection/
