- 1,004
fizzy said:This highlights the basic problem of the reverse play idea. You need to introduce a contrived means to have a secondary source of sound propagating in all directions behind the plane, including forwards. This will not happen with the plane as the source of the original sound. This does not provide a means to suggest that the firing the planes cannon would be heard in reverse playback.
Firing the cannon seems to give the most useful conceptual framework for examining how sound will propagate from a supersonic aircraft.
I see no credible explanation of how wave-fronts emanating form the plane could arrive at an observer in reverse order.
In my previous reply, which seems not to have caught little attention, I pointed out, that the theory of thin supersonic airfoils is basically the same as that of sound generation. Specifically a very thin blade which is either vibrating or maybe simply tilting (modulated with the song we want to hear backwards) may be a very good source of sound especially since an ideally thin, flat and untilted blade won't emit a supersonic boom.
Edit: The very point is that in this setting, the hydrodynamic equations can be linearized and these linearized equations are hyperbolic differential equations. The most important consequence is that sound can only propagate in the region bounded by the Mach cones from the trailing and leading edge. So there will be no sound emitted in the direction opposite to the motion of the airfoil.
