Can you derive SUVAT equations using a Langrangian?
The discussion revolves around the possibility of deriving the SUVAT equations using Lagrangian mechanics. Participants explore the theoretical implications and applications of Lagrangian methods in the context of classical mechanics, particularly focusing on motion under constant acceleration.
  • Some participants assert that it is possible to derive the SUVAT equations from the Lagrangian by applying the Euler-Lagrange equations.
  • One participant provides a specific Lagrangian and demonstrates how to derive equations of motion, suggesting that the SUVAT equations can emerge from this process.
  • Another participant questions the utility of applying Lagrangian mechanics to derive SUVAT equations, suggesting it may be unnecessary.
  • There is a correction regarding the formulation of the Lagrangian, emphasizing the need for time derivatives of position variables.
  • Some participants express the view that exploring these derivations is valuable for understanding physics, even if the SUVAT equations are not complex.
  • A participant unfamiliar with the acronym SUVAT seeks clarification on its meaning and context, prompting further explanation from others.
  • There is a discussion about the clarity of scientific communication, particularly regarding the use of acronyms and terminology.
Participants do not reach a consensus on whether applying Lagrangian mechanics to derive SUVAT equations is a waste of effort. While some argue it is beneficial, others contest this view. The discussion remains unresolved regarding the necessity and efficiency of using Lagrangian methods in this context.
Some participants express uncertainty about the derivation process and the assumptions involved in using Lagrangian mechanics. There are also varying levels of familiarity with the concepts discussed, which may influence the clarity and depth of the conversation.
This discussion may be of interest to students and enthusiasts of classical mechanics, particularly those exploring the connections between different formulations of motion and the application of Lagrangian methods.
gracie
Please help, I've put this is true on my personal statement, but I'm now fairly sure that it is not, but a more expert opinion would be extremely helpful.
Hello Gracie, welcome to PF :smile: !
Impressed you should be concerned with Lagrangians at 17 !
But, to answer your question: yes you can. Simply write down the Lagrangian and then the Lagrange equations of motion follow.
Give it a try and PF will help you further...
Of course! Lagrangian is equivalent to Newton's second law of motion in Cartesian coordinates.
$$L= {1\over 2}m(x^2+y^2)-mgy$$ apply Euler-Lagrange equation for x and y and you derive a differential equation whose solutions are SUVAT.
It is a waste for Lagrangian Mechanics to be applied on SUVAT!
The first term in that Lagrangian should have the derivatives of x and y in respect to time.
$$L={1\over 2}m({\dot x}^2+{\dot y}^2)-mgy$$
Now apply Euler-Lagrange equation for x and y, we get
$$m\ddot x=0 \tag{1}$$
$$m\ddot y=-mg \tag{2}$$
From (1),
$$\dot x =v_x= \text{constant}$$
From (2),
$$\dot y=v_y=\dot y_0-gt$$ and
$$y=y_0+\dot y_0t-{1\over 2}gt^2$$
So you see how these equations can be deduced in the case of a projectile.
Similarly you can apply it to a system of one degree of freedom and get the complete SUVAT equations.
However, it is a waste for Lagrangian Mechanics to be applied on SUVAT!
You are absolutely right, and it is embarrassing to know that I forgot to add the dots! As I punishment, I've written out the full procedures for Gracie.
What about the opportunity for gacie to discover this for herself ? "Give it a try and PF will help you further..." Then it woudn't have been a waste either !
(Don't agree that it's a waste in the first place :smile: !)
Thank you so much everybody, I thought I knew the answer but wanted proof from experts, I really appreciate it :)
May I ask if you are applying to UK or US?
UK
I know it's far above my present skill level, but understanding these sorts of thing even at a basic level is interesting for me, and you're right, it's not a waste of time, even though SUVAT are not complex I personally think it's amazing that something is so provable it can be done so in multiple ways. Physics is really cool ;3
This site has been really helpful with things I've struggled with, so thank you :)
Stupid question from a German: What's SUVAT? From the answers I get it's the motion of a particle in the constant gravitational field of the earth, but what means the acronym (it's good practice to write out any acronym once at its first appearance in the text).
Of course, the use of a Lagrangian is never a waste, because it's much more clear than using "naive mechanics" concerning the underlying principles and it immideately reveals the symmetries of the problem, if written down in the proper coordinates.
Google to the rescue:
s = distance (metres, m)
u = initial velocity (metres per second, ms^-1)
v = final velocity (metres per second, ms^-1)
a = acceleration (metres per second squared, ms^-2)
t = time (seconds, s)
And how can one derive distance, initial velocity and time, knowing only the lagrangian?
lightarrow
This was to help vanHees
So SUVAT stands for initial-value problem of the equations of motion of a point particle. Why don't you say so and use strange acronymes which are even imprecise when you resolve their meaning? Science should be expressed in as clear a language as possible!
Guess where I found it ? Here !
  • · Replies 18 ·
  • · Replies 25 ·
