Can You Solve the Square-Headed Architect's Museum Design Puzzle?
  • Context: Undergrad
  • Thread starter Thread starter FaustoMorales
    Riddle
The discussion revolves around a puzzle involving the design of a museum by a square-headed architect, where the building is structured as an nxnxh square box. Participants explore the constraints of the design, including the number of rooms, their area, perimeter, and connectivity. The conversation includes inquiries about specific values of n, potential solutions, and methods for generating designs, particularly focusing on symmetry and the use of n-polyominoes.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • Some participants discuss the known simple solutions for n=1, 2, 3, and 4, and question the existence of solutions for n=5.
  • Others mention that two solutions are known for n=6 and inquire about the possibility of finding more.
  • A participant suggests a technique involving regular graphs on n vertices to help generate new designs, particularly for larger n values.
  • It is noted that for n=5 and n=7, no suitable graphs exist that meet the specified conditions, raising questions about the compatibility of certain graph types with the design requirements.
  • One participant proposes that if rooms do not need square corners, there could be infinite possibilities for n=2 and n=4.
  • Another participant clarifies that the rooms should be made of n 1x1 squares, which may limit the designs previously considered.
  • Participants express interest in symmetric designs and share updates on a special project collecting such designs for various values of n.
  • Hints are provided for constructing designs for n=10, including specific graph construction techniques and conditions for room placement.
  • There is mention of at least one known solution for the 10x10 design, with a deadline for submissions set.
Participants generally agree on the constraints and requirements of the design but express differing opinions on the existence of solutions for specific values of n, particularly n=5, 7, and 10. The discussion remains unresolved regarding the completeness of solutions for larger n values and the effectiveness of proposed methods.
Limitations include the dependency on the definition of room shapes, the potential for multiple interpretations of graph constructions, and the unresolved status of certain mathematical claims regarding the existence of solutions for specific n values.
Readers interested in combinatorial design, graph theory applications in architecture, and mathematical puzzles related to spatial arrangements may find this discussion relevant.
FaustoMorales
This puzzle is about a square-headed architect who is designing a museum in the shape of an nxnxh square box, where n is an integer denoting the side length and h is the height of the building.
Building design is subject to the following additional constraints:
1. For any n chosen there will be exactly n rooms.
2. All rooms will have the same area n, in order to be able to hold similar crowd sizes.
3. All rooms will have the same perimeter so that they all have equal total wall areas.
4. All rooms will have the same number of neighboring rooms so as to be equivalent for the purpose of moving around the building.
Note: Two rooms are neighbors if they share at least a part of a wall, not just a corner.
QUESTIONS:
1. Simple solutions can be found for n=1,2,3 and 4. Can you check this?
2. No solutions are known for n=5. Are there any?
3. Two solutions are known for n=6. Can you find them? Are there more?
4. Are there solutions for n>6? Can we help the architect find interesting (i.e., large n) designs?
Mathematics news on Phys.org
HINT:
Here is a technique that may help produce new solutions:
1. For each value of n that you choose to investigate, construct or look up regular graphs on n vertices with degree > 2 that can be drawn without crossings between edges (i.e., with edges meeting only at vertices).
2. For each such graph, take the vertices to represent n-polyominoes with the same perimeter and take the edges between vertices to mean that the corresponding n-polyominoes are neighbors.
3.Try to produce a design with n-polyominoes in an nxn square consistently with the connectivity conditions specified by the graph.
Repeat this procedure for any regular graph on n vertices of the type specified that looks promising.UPDATE 1:
I decided to follow my own hint and came up with several solutions for n = 8, two of them with mirror symmetry. Can you find these? Is it possible to find designs for n > 8?
UPDATE 2:
The situation is much less promising for n = 5 and n = 7, since there are no graphs of the type specified by the hint (a.k.a. connected regular planar graphs) with degree > 2.
Can we actually prove that the only connected regular planar graphs of each size (the pentagon graph and the heptagon graph, respectively) are incompatible with any possible solutions to the design? This shouldn't be hard.
n=9 holds better chances, since there is a connected regular planar graph with degree 4 that might do the trick.
If the rooms do not need square corners then there are infinite possibilities for n=2,,4 due to symmetry.
You are right. The statement did not clarify -but should have- that the idea is to use shapes for the rooms made up by joining n 1x1 squares side by side (a.k.a. n-polyominoes). That was the purpose of stating that the side length of the complex is an integer.
Please introduce this constraint in your designs.
Aww, and I had all these rooms with interesting shapes (that actually had square corners).
I guess they don't count now?
Sorry about that... On the brighter side, you'll see how many interesting shapes you'll be able to make when you find larger n solutions!
SPECIAL PROJECT:
Our square-headed architect would definitely prefer museum designs with some sort of symmetry, in addition to the rest of requirements (splitting the nxn square into n-polyominoes, all with the same perimeter and the same number of neighboring rooms), so we are also putting together a special collection to that effect.
This collection contains 15 symmetric designs so far:
n=1: The trivial design
n=2: 1 mirror-symmetric design
n=4: 2 mirror-symmetric designs and 2 designs with 90º rotation symmetry
n=6: 2 mirror-symmetric designs
n=8: 3 mirror-symmetric designs
n=9: 4 designs with 180º rotation symmetry
Use your cleverness and the hint on graphs from a previous post to find these designs and many others that will extend this very special collection.
Good luck!
UPDATE ON THE SPECIAL PROJECT
The collection keeps growing and already contains 23 symmetric designs.
n=9: 12 designs with 180º rotation symmetry
The next big challenge ahead is to go for the n=10 record.
HINTS:
1. Build connected, planar (no crossings between edges), 4-regular graphs and study their suitability to represent connections of 10-polyominoes of the same perimeter symmetrically placed within a 10x10 square. Keep in mind that the same graph may have several potentially useful planar embeddings (i.e. "presentantions" on the plane).
2. A trick to get you started with the graphs:
a. Put 4 vertices in a square configuration and join them with edges to form a square.
b. Similarly, use 6 more vertices to place a hexagon within the square.
c. Draw 2 more edges between vertices of the hexagon (you have some choices here).
d. Complete the graph by connecting some vertices of the square with some vertices of the hexagon, so that when you are done each vertex is connected to 4 others and there are no crossings between edges.
e. See if you can use your graph to help you produce a correct partition of the 10x10 square into 10-polyominoes. If not, repeat steps (c) and (d) and try again.
Have lots of fun!
Oh, in case you were wondering: at least 1 solution exists to the 10x10 design. I will post it on September 2, unless someone can find it first...
Good luck!
We extend the deadline for solutions until September 22.
Hints for the 2 symmetric solutions known so far to the 10x10 design:
1. Each corner of the 10x10 square belongs to a different room.
2. Each 1x1 cell of the central 2x2 square belongs to a different room.
Can you find them both?
Good luck!
  • · Replies 68 ·
12K
  • · Replies 125 ·
20K
  • · Replies 19 ·
