Can You Solve This Initial Value Problem and Determine Its Solution Interval?
  • Topic:
  • Thread starter Thread starter karush
    Explicit Form Ivp
7 replies · 4K views
karush
MHB
Given #11
$\quad\displaystyle
xdx+ye^{-x}dy=0,\quad y(0)=1$
a. Initial value problem in explicit form.
$\quad xdx=-ye^{-x}dy$
separate
$\quad \frac{x}{e^{-x}}\, dx=-y\, dy$
simplify
$\quad xe^x\, dx=-y\, dy$
rewrite
$\quad y\,dy=-xe^x\,dx$
integrate (with boundaries)
$\quad \int_1^y u\,dy=-\int_0^x ve^v\,dv$
OK i did this so far hopefully ok but didnt know how to do b and c (on desmos)
b. Plot the graph of the solution
c. Interval of solution.
Re: 11.2
I recommend that you integrate both side to find the curve and the graph as well as provide that answer to us.
Re: 11.2
(You have a typo- your "dy" should be "du".)
Why stop there? Obviously you have to do the integrals! The "du" integral is straight forward. To do the "dv" integral, use "integration by parts".
Solving for y will involve a square root. The domain is determined by the fact that the square root must be of a non-negative number. The graph will have two parts, one with "+", the other with "-".
Re: 11.2
What title would you like me to give this thread so that the title is useful?
Re: 11.2
11.2 Initial value problem in explicit form.
I tried to fix it but couldn't
$$\int_1^y y\,dy=-\int_0^x xe^x\,dx$$
then
$\frac{y^2}{2}-\frac{1}{2}=-e^xx+e^x-1$
isolate y
multiply thru by 2 and add 1
$y^2=-2e^xx+2e^x-2+1$
simplify RHS and factor
$y^2=2[1-x]e^x-1$
square both sides
$y = 2[(1-x)e^x-1]^{1/2}$
typo maybe??
when this is graphed you get nothing?
Re: 11.2
karush said:
thake the square (root) of both sides
typo maybe??
The "2" belongs under the square root. Typo? (Sun)
Here's the graph. I have no idea why this would cause you trouble.
And don't forget the part of the solution with the negative sign!
-Dan
here is the desmos attemptalso I don't know where the interval of $−1.68<x<0.77$ which is the book answer comes from
I set y=0 but that didn't return those values
What values did you get? If I graph the function on Desmos (https://www.desmos.com/calculator) clicking on the y-intercept, I get x= -1.678 and x= 0.768)
If y= 0 then [tex]2(1- x)e^x- 1= 0[/tex] then [tex]2(1- x)e^x= 1[/tex].
Let u= 1- x so that x= 1- u. The equation becomes [tex]2ue^{1- u}= 2eue^{-u}= 1[/tex]. Let v= -u so that u= -v. The equation becomes [tex]-2eve^v= 1[/tex]. Divide both sides by -2e. [tex]ve^v= -\frac{1}{2e}[/tex]. Then [tex]v= W\left(\frac{-1}{2e}\right)[/tex] where "W" is "Lambert's W function, defined as the inverse function to [tex]f(x)= xe^x[/tex].
