Can You Travel Faster Than The Speed Of Light?
The discussion revolves around the question of whether it is possible to travel faster than the speed of light, exploring theoretical implications, relativistic physics, and speculative scenarios. Participants engage with concepts from physics, including energy equations and the nature of light in different media.
  • Theoretical physics
  • Some participants reference the equation E=γMoC² to argue that achieving or exceeding the speed of light would require infinite energy, suggesting that it is impossible to reach light speed in a vacuum.
  • Others propose that while one cannot travel at the speed of light, it may be possible to approach it asymptotically, with increasing mass requiring more energy as speed increases.
  • A participant mentions the concept of Cherenkov radiation as a phenomenon that occurs when an object exceeds the speed of light in a medium, but not in a vacuum.
  • Some argue that time dilation allows for different perceptions of light speed from different frames of reference, complicating the discussion about relative speeds.
  • There are speculative ideas about altering the medium through which light travels, suggesting that if light could be slowed down, it might allow for faster-than-light travel in some contexts.
  • One participant introduces the notion of tachyons as hypothetical particles that could travel faster than light, although this remains speculative.
  • Another participant humorously suggests that one can observe stars moving faster than light through non-inertial motion, raising questions about the nature of motion and speed.
Participants generally disagree on the possibility of faster-than-light travel, with some asserting it is impossible while others explore speculative scenarios. There is no consensus on the interpretations of relativistic effects or the implications of various physical theories.
Some arguments rely on specific interpretations of relativistic physics and the implications of energy equations, which may not be universally accepted. The discussion includes speculative elements that are not grounded in established scientific consensus.
This discussion may be of interest to those exploring theoretical physics, relativistic concepts, and the implications of light speed in various contexts, as well as individuals curious about speculative ideas in physics.
WARLORDTF
This Question begs an answer and that is impossible but I'm sure we can agree on one 'unified answer'
I Know from a lecture about energy needed to travel at the speed of light and found:
E=(Gamma)Mo(Mass In A Stationary Postiton)C2 (Constant/Speed Of Light)
Now according to this formula there cannot be an answer for 99.999999...%< as Gamma
Gamma=√1-v2 (squared) V Is the index form of the speed of light 99%=0.99
this 'supposedly' proves there cannot be a speed greater than or equal to 100% of the speed of light.
could someone prove this wrong...?
I will post another theorem with this to help justify both answers.
:smile:
No, "you cannot travel faster than the speed of light."
I think you should review the forum rules before you make any more posts, especially the part regarding "overly speculative posts."
sorry :)
Theorectical physics is, by inherent nature, speculative. But it also demands responsibility of factual foundation as a basis for the speculative.
It is not enough to ask "what if", rather the demand is to base the "what if" on established facts or to pursue a course of action to establish new facts for support.
This is very difficult... best of luck.
Correct me if I am mistaken:E=mc2 does not prove you cannot travel faster than light.I thought the fact that the speed of light in vacuum is constant(supported by experiments).So if a spaceship travels at c and has a headlight...an observer would measure the light beam and the spaceship to be at the same point(because the light beam goes at speed c and spaceship also goes at speed c).However,the speed of the light beam RELATIVE to the spaceship should be c.This contradicts the spaceship and the light beam being at the same point.And therefore we can never go at nor faster than the speed of light.
:smile:
actually, you can get as close as possible to the speed of light, but you cannot reach the speed of light in a vaccuum, because it would take an infinite impulse to reach the speed of light.
The paradox you point is solved by time being relative. An observer would see the light moving forward just slightly faster than the spaceship. The time inside the moving spaceship moves slower so people on the spaceship would still see light moving at c.
As matthias points, you need an infinite impulse to reach c as your mass is increasing with speed, and that's why is not possible to move faster than c.
You can move faster than the light but not in vacuum.
Right; hence Cherenkov radiation. As I understand it, though, the equations rule out only an object with mass traveling at the speed of light. The speculation about the existence of tachyons was based upon the possibility of something having c as it lower speed limit.
however if we found a state of essence that light could be slowed down in and propelled an item faster than this wouldn't that still create the same effects as this whole discussion is Based around E=γMoC2 where C is the speed of light in a vacuum if we change the C Variable into... say... Diamond Or excited gas where the light is slowed down then it would take a considerable less amount of energy to do this.
In my dreams...
Just look at the stars and start spinning around on your feet.. you will observe the stars to move faster than c. My point is that things can travel faster than c if we aren't talking about inertial motion. What exactly is it you wan't to know?
:smile:
Velocity addition has no limit as it is a hyperbolic function. Pseudo-rotations in spacetime due to accelerations cannot turn from a timelike to a nullike path.
Hello MeJennifer
The first remark about velocity addition I understand a little; do you mean it is an algebraic property with parallel consequences in geometry on hyperbolic surface? But the second about fourdimensional knowledge; could you enlighten me a little more?
greetings Janm
WARLORDTF said:
however if we found a state of essence that light could be slowed down in and propelled an item faster than this wouldn't that still create the same effects as this whole discussion is Based around E=γMoC2 where C is the speed of light in a vacuum if we change the C Variable into... say... Diamond Or excited gas where the light is slowed down.
No, you cannot do that. The equation is [itex]E=\gamma m c^2[/itex], and c is the speed of light in vacuum. It is perfectly possible for something to go faster than the speed of light in a medium, but never faster than c. When it does, the body releases Cerenkhov Radiation.
You guys are responding to posts from May 2008, the original posters probably aren't around any more.
Oh well. My argument still stands ;)
Hello ZikZak
If you want to use an energy formula of v, it is not appropiate to use the one for total energy, but rather use:
E_kin=gamma m c^2 - m c^2
Note that v=0 implies E_kin=0 as it should.
greetings Janm
WARLORDTF said:
sorry :)
its ok :)
oh wait, you wernt talking to me
Ok. Your question is that can you travel at the speed of light? Well, I'm sorry, you cannot. According to Einstein's General Theory of Relativity, simplified, E=MC2, it is directly stated that nothing may travel at the same speed of light, especially in a vacuum, which is the circumstance in space.Yet, there is a speed that far exceeds this, where particles travel at 1/1000000000000000000000000000000000000, or 6 millionth of a second. However, there is a twist. This speed is impossible to achieve in space but SPACE itself travels at that speed. Though this is only theoretical physics, because these rates are only recorded in the Big Bang. Hope I helped a bit. :smile:
Let's suppose one cannot travel faster than speed of light but can travel "At" speed of light for the purpose of this speculation.
Here's the scenario:
Master Vader, after having won the Ultimate Championship of Golf on Earth, takes off in the Ultra Luxury Space Ship Lady Gaga at the speed of light towards Intergalactic Jedi Golf Federation Hall of Fame in Delta Quadrant.
Half way through the journey he notices Kendomaster returning from exile in a Compact Space Ship Volt at barely attained speed of light towards Earth.
Before Vader could say "hello" both space ships pass each other and are traveling at opposite directions.
"That Kendomaster...he must not know the Ultimate Championship of Golf is over. Always late. Poor chap," thought Master Vader.
Now. Both Master Vader's Ultra Luxury Space Ship Lady Gaga and Kendomaster's Compact Space Ship Volt are traveling at the speed of light. However, since they are traveling at precisely opposite direction each ship is traveling 2x the speed of light away from each other.
Applying Einstein's Theory of Relativity, speed of a moving object must be measured from a point relative to it's previous position to be exact. But that measured speed only applies to the moving object itself and not to any other object outside of it.
From Kendomaster's point of view Vader is moving away from him at 2x the speed of light. And vice versa.
To answer the quesion, "Can you travel faster than the speed of light?", the answer is no according to the equation. However, you can be traveling away from another object at 2x the speed of light if the other object is also traveling at speed of light in opposite direction.
So the ultimate rule in space travel seems to be that no two objects can move away from each other faster than 2x the speed of light, relative or not.
(1) Their speed cannot be equal to the speed of light. You can make the same point (and same error) using speeds of 0.99c.
(2) What is their speed with respect to?
Not true.
Huh?
Nope.
Perhaps you are confusing what can be called the closing speed of the two ships as seen by a third observer. For example if ship A travels east at 0.99c with respect to earth while ship B travels west at 0.99c with respect to earth, then earth observers will say they are closing the distance at a rate of 1.98c. But note that nothing is really moving at that speed.
Relative to ship A, ship B is approaching at about 0.9999c (not 1.98c).
if i go through a wormhole aren't i traveling faster than light or does this have something to do with space-time? is there an equation for a spacewarp or are whormholes just sci-fi? how do i inform myself about the physics of wormholes?
sure i can travel faster than the speed of light
correct me if I'm wrong but,when we use the equation E=mc2 the mass [m] no longer remains the same [constant] at higher speeds...the mass is then expressed as
m=mo/[1-(v/c)2] ...so,as v [speed] approaches c the denominator approaches infinity...
thus,this tells us that to achieve the speed of light infinite amount of energy is necessary..
which is practically not possible..
Sorry to hijack this thread but I am sort of confused.I had a recent interview t study Astrophysics (UG).There I met one of the lecturers who has spent considerable amount of time on particles physics (his main subject of interest) and as such has permission to places such as CERN,LHC and so on.From what I have heard they had successfully made a beam of electron travel 100% to that speed of light. I wonder if these are actually called relativistic electrons ?
Wormholes work on a different principle. At no point do you travel faster than the speed of light between two points because the distance between the two points becomes zero (or as small as possible).
Wormholes a strictly theoretical at the moment and there is no direct evidence they exist.
Not appropriate and a waste of a post.
Correct, you require infinite energy for any object with mass to travel at c.
No, they've never achieved 100%.
lf light speed is the passport to traveling into the future, what is the ticket to traveling into the past, what is the oapasate of light speed? dark speed? or dark matter? you tell me?
it has something to do with reversing your polarity. if you have the polarity of antimatter you have to accelerate to go slower than light but can always travel faster.
Speed of light is a local limit. That's the real reason that GR allows you travel faster than light in global sense. That is, for any large distance d, you can travel it in less than d/c. You don't even need a wormhole for that one. Look up Alcubierre Warp Drive.
Of course, the problem is that all known geometries allowing FTL travel require negative energy densities, and it's unclear whether these are possible. Worse, creating a wormhole requires altering of topology, for which there is no known mechanism.
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 26 ·
