Cannon ejecting bullets moving on surface with friction
6 replies · 2K views
Tanya Sharma
A cannon of total mass [itex]m_{0}[/itex] is at rest on a rough horizontal road.It ejects bullets at rate of λ kg/s at an angle θ with the horizontal and at velocity u (constant) relative to the cannon .The coefficient of friction between the cannon and the ground is μ .Find the velocity of the cannon in terms of time t .The cannon moves with sliding .
Answer : [itex]v = - μgt + ( ucosθ - μusinθ)ln[\frac{m_0}{m_0-λt}][/itex]
Taking the positive direction of x-axis towards right ,cannon is to move rightwards and eject bullets leftwards
We define system to comprise of (cannon + bullets)
Let M be the mass of the system at time t
then M-dm be the mass of the system at time t+dt
V be the Velocity of the system at time t
V + dv be the velocity of the system at time t+dt
Now [itex]\frac{dm}{dt}=-λ[/itex]
N=Normal force on the system from ground
Now in the vertical direction
Momentum of the system at time t = 0
Momentum of the system at time t + dt =(M-dm)(0) +(dm)(usinθ)
[itex]dp=(dm)(usinθ)[/itex]
[itex]\frac{dp}{dt}=\frac{dm}{dt}(usinθ)[/itex]
[itex]\frac{dp}{dt}=(-λ)(usinθ)[/itex]
now [itex]F_{ext}=N-Mg[/itex]
[itex]\frac{dp}{dt}=F_{ext}[/itex]
[itex]N-Mg=(-λ)(usinθ)[/itex]
[itex]N=Mg-λusinθ[/itex] (1)
In the horizontal direction
Momentum of the system at time t = MV
Momentum of the system at time t + dt =(M-dm)(V+dv) +(dm)(-ucosθ+V+dv)
dp=MV + Mdv - dmV - dmdv - dmucosθ +dmV +dmdv -MV
dp=Mdv - dmucosθ
[itex]\frac{dp}{dt}=M\frac{dv}{dt}-\frac{dm}{dt}(ucosθ)[/itex]
[itex]\frac{dp}{dt}=(-λ)M\frac{dv}{dm}+λucosθ[/itex]
[itex]F_{ext}=-μN[/itex]
[itex]F_{ext}=-μ(Mg-λusinθ)[/itex]
[itex]\frac{dp}{dt}=-μ(Mg-λusinθ)[/itex]
Thus,we have
[itex]-μ(Mg-λusinθ) = (-λ)M\frac{dv}{dm}+λucosθ[/itex]
[itex]-μMg + λμusinθ = (-λ)M\frac{dv}{dm}+λucosθ[/itex]
Diving by -λ throughout,we get
[itex]\frac{μ}{λ}Mg - μusinθ = M\frac{dv}{dm} - ucosθ[/itex]
[itex]M\frac{dv}{dm} = \frac{μ}{λ}Mg -μusinθ + ucosθ[/itex]
putting [itex]λ = -\frac{dm}{dt}[/itex] ,we get
[itex]M\frac{dv}{dm} = -μMg\frac{dt}{dm} +( ucosθ - μusinθ)[/itex]
[itex]dv=-μgdt + ( ucosθ - μusinθ)\frac{dm}{M}[/itex]
[itex]\int_{0}^{v}dv = -μg\int_{0}^{t}dt + ( ucosθ - μusinθ)\int_{m_0}^{m_0-λt}\frac{dm}{m}[/itex]
[itex]v = - μgt + ( ucosθ - μusinθ)ln[\frac{m_0-λt}{m_0}][/itex]
which gives
[itex]v = - μgt - ( ucosθ - μusinθ)ln[\frac{m_0}{m_0-λt}][/itex]
This is not the correct answer...kindly help me with the problem ...
Check the signs. If Δm is the mass of a ball, it is positive. Ejecting a ball, the mass of the cannon decreases. If the cannon ejects balls so the rate of the ejected mass is λ, the mass of the cannon is M(t)=mo-λt.
By ejecting a ball, the vertical momentum of the cannon-ball system increases, as the ball gets the vertical velocity vy=usin(θ), and the vertical velocity of the cannon does not change. The change of the vertical component of momentum is Δm*usin(θ)=λΔt*usin(θ) and it is equal to the impulse of the external force: (-Mg+N)Δt, so N=Mg+λusin(θ): ejecting balls increases the normal force.
ehild
ehild...thanks for the response...Considering what you have suggested , I have amended my work ...but again I arrive at an incorrect answer
Now [itex]\frac{dm}{dt}=λ[/itex]
[itex]\frac{dp}{dt}=(λ)(usinθ)[/itex]
[itex]N-Mg=(λ)(usinθ)[/itex]
[itex]N=Mg + λusinθ[/itex] (1)
dp=Mdv - dmucosθ
[itex]\frac{dp}{dt} = λM\frac{dv}{dm} - λucosθ[/itex]
[itex]F_{ext}=-μ(Mg + λusinθ)[/itex]
[itex]\frac{dp}{dt}=-μ(Mg + λusinθ)[/itex]
Thus,we have
[itex]-μ(Mg + λusinθ) = λM\frac{dv}{dm} - λucosθ[/itex]
[itex]-μMg - λμusinθ = λM\frac{dv}{dm} - λucosθ[/itex]
Diving by λ throughout,we get
[itex]\frac{-μ}{λ}Mg - μusinθ = M\frac{dv}{dm} - ucosθ[/itex]
[itex]M\frac{dv}{dm} = \frac{-μ}{λ}Mg -μusinθ + ucosθ[/itex]
putting [itex]λ = \frac{dm}{dt}[/itex] ,we get
which gives
Again I arrive at the same incorrect answer . Where am I getting it wrong??
On system you mean the cannon and the balls still inside.
So dm is the mass of a ball. And the time derivative of the mass is dM/dt=-λ.
dp=Mdv - dmucosθ
Beware: dm is the mass of a ball. M is the mass of the system. dM/dt=-λ.
M is a variable. dm is not. Keep t as independent variable. M=M0-λt.
[itex]\frac{dp}{dt} = M\frac{dv}{dt} - λucosθ[/itex]
Thus,we have
Keeping t as independent variable,
[itex]-μMg - λμusinθ = M\frac{dv}{dt} - λucosθ[/itex]
Substitute M=Mo-λt, collect the terms containing t and integrate.
ehild
ehild ...what you have suggested is excatly what i did initially...Kindly look at post #1
If i write [itex]\frac{dm}{dt}=-λ[/itex] then N =Mg - λusinθ and again we arrive at the same incorrect result ...
Kindly have a look at the initial post...
I suggested to keep the time as independent variable. dm/dt is not -λ. dm≠dM. Please, read my previous post. You integrate with respect to the mass, which is M. dm is the loss of mass when a ball is ejected. dM=-dm. dM/dt=-λ.
ehild
