Cannot find V and I in this circuit
  • Thread starter Thread starter alacey11
    Circuit
The discussion focuses on solving a circuit problem to find the current (i) and voltage (v) values, specifically i = 6 Amps and v = 3 Volts. Participants utilized Ohm's Law, Kirchhoff's Current Law, and Kirchhoff's Voltage Law to approach the solution. A key insight was the distinction between conductance (Siemens) and resistance (Ohms), which clarified the method of combining resistances in series and parallel. Ultimately, the correct approach involved converting conductances to resistances for accurate calculations.
  • Understanding of Ohm's Law
  • Familiarity with Kirchhoff's Current Law
  • Knowledge of Kirchhoff's Voltage Law
  • Basic concepts of electrical resistance and conductance
  • Study the conversion between conductance (Siemens) and resistance (Ohms)
  • Learn how to apply Kirchhoff's Laws in complex circuits
  • Explore series and parallel circuit analysis techniques
  • Practice solving circuit problems using Ohm's Law
Electrical engineering students, circuit designers, and anyone looking to enhance their understanding of circuit analysis and electrical principles.
alacey11
Obtain the values of i and v in the circuit below:
http://img33.imageshack.us/img33/7538/newpicturenl.png
Answers: i = 6 Amps, v = 3 Volts
Ohm's Law, Kirchhoff's Current Law & Kirchhoff's Voltage Law
I have spent the last 90 minutes on this question!
I can see that it is simple, but I must be approaching it wrong as I keep on getting the same wrong answers.
I just need to know where to start...
Thanks
id try combining the furthest resistances to the right because it is a series circuit, to get 9S then finding the total resistance of that and 2S which is 1/9S+1/2S=1/Rt ->2/18+9/18->11/18->18S/11= Rt. then find the total resistance of that and4s because its a series circuit. so its 18S/11 + 4S which is 62S/11... not sure if this is correct/and if it is idk where to go from there
You approached it the same way I did :)
I thought that way would work, but I kept ending up with i = 1.35 A
hmm, couldn't you do it that way then "simplify" it to a series circuit so I is constant. then can't you do V=IR and plug in 9 for Itotal and whatever the total resistance was for R and find V total? only problem here is S though.
The S unit is Siemens, which is conductance, not resistance. For an individual resistor, S = 1/R. This means that conductances in parallel add, while those in series add like resistances in parallel.
Sometimes it's easier just to convert all of the individual conductances to resistances...
I had no idea they were different units!
I thought the S was a variable...
Thank you for clearing that up for me - I've solved the question now, thanks. :smile:
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 31 ·
  • · Replies 18 ·
