Can't do this supremum question
  • Thread starter Thread starter kramer733
    Supremum
The discussion revolves around a problem related to the concept of supremum in the context of sequences and limits. Participants are examining the properties of a sequence \( a_n \) and its relationship to a bound \( b \), particularly in the context of proving that the limit of the sequence is less than or equal to the supremum of the sequence.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants are exploring the definition of supremum and its implications, questioning whether \( b \) represents a single number or a set of numbers. There is also discussion about the conditions under which the limit of the sequence exists and how that relates to the upper bound.
There is an ongoing exploration of the definitions and properties related to the supremum and the sequence. Some participants have offered hints and suggestions regarding the use of subsequences to approach the problem, indicating a productive direction in the discussion.
Participants are grappling with the definitions of upper bounds and limits, and there is some uncertainty about the interpretation of \( b \) in relation to the sequence \( a_n \). The original poster expresses a need for clarification on proving certain properties related to the supremum.
kramer733
here's the picture and it's the second part of question 5:
http://imgur.com/ybSW4v4
N/A
so by intuition, I suspect that b = sup{a_n: n is in the natural numbers}
If we can show that, then it will follow from the first part of question 5 that what we are trying to prove does hold.
Ok well the problem is this. I'm given the definition of Least Upper Bound:
1) b is an upperbound
2) if y is an upperbound of the set, then (y > b) or (y = b).
I'm not sure how to prove 2) at all.. I need major help =/ Please..
The question is: $$\text{Q5. }\text{Suppose that }a_n\leq b\text{ for all } n \text{ and that } a=\lim_{n\rightarrow \infty} a_n \text{ exists. }\\
\text{5.1 Show that }a\leq b\text{. }\\
\text{5.2 Conclude that } a\leq \sup_n a_n = \sup_n \{ a_n : n\in \mathbb{N} \}$$
... hmmm, how to describe it...
if A={1,2,3}, then sup[A] = what?,
if an ≤ b, what is b?
Is b supposed to be a single number or a set of them?
What does it mean to say "## a=\lim_{n\rightarrow \infty} a_n## exists"?
Oh crap... For whatever reason, i parsed "b" to be the number such that it is greater than AND equal to an. Thank you. So b is a set of numbers that satisfy an≤ b right?
I'm working on this same question. I believe b is supposed to be a real number so that the sequence is bounded.
I've posted a hint in Zondrina's post; you can check it out there: https://www.physicsforums.com/showthread.php?p=4364873#post4364873
Basic idea: consider two subsequences of your sequence [itex]a_n[/itex], one that is decreasing, and one that is increasing. Show that if you have an decreasing sequence, then your inequality is satisfied. Show that this also holds for increasing sequences. Conclude that this inequality is valid for your original sequence.
9K
