Can't find my Localhost Database Engine for SQL Server
3 replies · 3K views
Discussion
Mentor
- 15,811
- 10,700
Did you try using the actual tcpip address of your host or the 127.0.0.1 to test that it works ?
Did you try searching on google to see if others had the same problem? It may well be a product issue.
Review your install confit stuff to see you have to place anything in the Microsoft Windows registry ?
willem2
- 2,134
- 395
Can you start SQL server configuration manager? You probably need the check if the sql server browser service running. The TCP/IP network protocol should be enabled. Look if what the name of the instance of SQL server is, and don't browse, but connect to COMPUTERNAME\INSTANCENAME. Look at https://docs.microsoft.com/en-us/sq...-connecting-to-the-sql-server-database-engine See the steps under "testing a local connection"
If that doesn't work look in the windows eventlog if there were any errors during startup of sql server (restart services with configuration manager if necessary).
Creating a remote client-server front end for SQL Server database
- WWGD
- · Replies 18 ·
- Programming and Computer Science
- Replies
- 18
SQL Server Configuration Manager missing after Express 2017 install
- WWGD
- · Replies 8 ·
- Computing and Technology
- Replies
- 8
