Can't Rearrange this equation ?
  • Thread starter skaboy607
    Rearrange
12 replies · 3K views · last reply
skaboy607
Can't Rearrange this equation!??
I need to substitute one equation into another and rearrange for one term. I can't get the right answer!
I've had to attach the equations as pictures I am afraid, here they are.
The equation to be substituted-http://i423.photobucket.com/albums/pp315/skaboy607/Tobesubstituted.png
Main Equation-http://i423.photobucket.com/albums/pp315/skaboy607/MainEquation.png
What I can't get!-http://i423.photobucket.com/albums/pp315/skaboy607/FinalEqthatIcantget.png
I have a few extra terms when I rearrange, it is driving me mad!
Thanks for your help.
Make your life easier by writing a=ms^2+Bs+K and c=Bs+K. Also write X instead of X(s) and Y instead of Y(s). Note X=aY/c. Simplify as much as you can. Then substitute a=ms^2+c and simplify some more. It works out.
ok, so far I using your easier notation I have U=cX-cY+Ms^2X, then with substitution, U=caY/c-cY+Ms^2aY/c.
Is this what you meant? I am confused now with when to put a=ms^2+c.
Thanks
You're doing it backwards from the way I did it.
First I rewrote "main equation" as U(s) = etc. Call this "new main equation."
Then I used the easier notation in "tobesubstituted", then substituted into "new main equation." Then I simplified, etc.
From time to time I looked at the goal "FinalEqthatIcantget" but I didn't start with it.
Ok so starting from scratch, my rearranged 'main equation' looks like U=Ms^2X+kX-kY+bsX-bsY. Then Substituting in the easier notationed 'tobesubstitued' I have:
U=Ms^2aY/c+kaY/c-ky+bsaY/c-bsY.
This along the right lines?
I can't simplify that any further so shall I replace my values for a and c in now, then simplify?
Thanks
ok...do you mean multiply both sides by c to cancel it out? I tried without getting rid of the fractions, and was stuck with the same terms again as before that I can't get rid of. This are '2kbs', '(bs)^2', 'k' and 'k^2'. If it helps this is the equation where I am at.
U=(Mms^4+Mbs^3+Mks^2+kms^2+kbs+k^2-k+mbs^3+(bs)^2+kbs-bs)Y/c
Sorry if I am being stupid!
Aha! Common denominator problem (or similar).
Early on, you should have written Y=cY/c.
erm...i'm lost, where should that have been? Wouldn't the c's cancel to leave Y=Y anyway?
Look at right hand side. Get the common denominator here. Three terms have denominator c, but two don't.
