Cantilever Beam First Mode of Vibration
The discussion focuses on identifying the first mode of vibration in a cantilever beam, particularly distinguishing it from other frequencies. A COMSOL model was used to calculate the first six modes of vibration, prompting curiosity about real-world examples. To differentiate between the first mode and other vibrations, one can observe increased amplitude at specific frequencies during excitation. Measuring amplitude versus frequency reveals peaks that correspond to the beam's resonant frequencies. Visual cues, such as increased amplitude, can also help identify when the beam is near its normal modes.
Oscar6330
I developed a COMSOL model and calculated the first 6 modes of vibration of cantilever beam. Later out of curiosity, I looked up some videos on youtube to see actual cantilever. I found this video which shows the first mode.
How do you know that its first mode of vibration? More specifically, how do you differentiate between normal vibrating beam and first mode (they look quite the same)?
any help please!
What do you mean by "normal vibrating beam"?
From Normal vibrating beam/ cantilever, I mean a beam which is vibrating at a freq other than its mode freg. For e.g if first mode a beam is at 100 hz and its vibrating at 40Hz.
Now I understand. One way to go is the following:
If you vibrate the cantilever and change the excitation frequency continuously, you can tell the normal modes by an increased amplitude. For low damping this may be very sharp.
If you measure amplitude versus frequency, you will see some peaks corresponding to the normal modes (or resonant frequencies).
For the setup in the clip I guess you can tell visually when it is near the normal mode, from the increased amplitude.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 0 ·
