What Is the Capacitance of Coaxial Infinite Cylinders?
The capacitance of coaxial infinite cylinders is determined by the formula that relates it to the natural logarithm of the ratio of their radii, specifically expressed as inversely proportional to Ln(r_{1}/r_{2}). To achieve an infinite capacitance, the lengths of the cylinders must be extended infinitely rather than minimizing the radii to zero, which leads to an indeterminate form. The discussion clarifies that the problem likely seeks the capacitance per unit length, which provides a finite solution despite the infinite nature of the cylinders.
  • Understanding of electrostatics and capacitance concepts
  • Familiarity with coaxial cable geometry
  • Knowledge of logarithmic functions and their properties
  • Basic principles of limits and indeterminate forms in calculus
  • Study the derivation of capacitance for coaxial cylinders using electrostatic principles
  • Learn about the concept of capacitance per unit length in cylindrical geometries
  • Explore the implications of infinite lengths in electrostatic problems
  • Review advanced calculus techniques for handling indeterminate forms
Students studying electromagnetism, electrical engineers, and physicists interested in the theoretical aspects of capacitance in cylindrical geometries.
Void123
I have two coaxial infinite cylinders and I must find their capacitance, where r_{1} < r_{2}
I got an answer (for finite cylinders) that is inversely proportional to Ln (r_{1}/r_{2}).
Assuming this answer is correct (if someone can check it), in order to make it infinite the two radii have to become infinitesimally small (0) correct? If I do this though, I get an indeterminate in the argument of log.
Have I done this wrong or must I rewrite my expression in terms of some approximate expansion?
Are you sure the problem isn't asking you for the capacitance per unit length?
I am sure. I don't see how significant that is either, since I would just divide my expression by l. But, the road block at the moment is trying to infinitesimally minimize the radii so as to give me a finite solution.
It's significant because the reason you get an infinite answer is because l is infinite. Typically, this type of question asks you for the capacitance per unit length, which is a finite number.
No, in order two make the two cylinders infinitely long, you just make them longer.
  • · Replies 16 ·
