Capacitance with Non-Uniform Dielectrics
The discussion focuses on calculating the capacitance of a parallel plate capacitor filled with a non-uniform dielectric characterized by a permittivity ε = ε0 + ax, where 'a' is a constant and 'x' is the distance from one plate. The relevant equations include C = Q/V, P = XeE, and the relationship between electric displacement D and polarization P. The solution involves substituting the electric field from a parallel plate capacitor into the capacitance formula and integrating to find the voltage, ultimately leading to the capacitance calculation.
  • Understanding of parallel plate capacitor theory
  • Familiarity with dielectric materials and their properties
  • Knowledge of electric field and potential relationships
  • Basic calculus for integration in electric field calculations
  • Study the derivation of capacitance for non-uniform dielectrics
  • Learn about electric susceptibility and its impact on dielectric materials
  • Explore the integration techniques for calculating electric potential
  • Investigate the effects of varying dielectric constants on capacitor performance
Students in electrical engineering, physicists studying electromagnetism, and professionals working with capacitors and dielectric materials will benefit from this discussion.
Durin
1. A parallel plate capacitor, with plates of area A, and spacing d, is filled with a non-uniform
dielectric, with a permitivity that varies as
ε = ε0 + ax
where a is a constant, and x is the distance from one plate
C = Q/V
I'm assuming I'm allowed to assume this is a linear dielectric so
P = XeE
D = P + E = (1+Xe)E = εE
Where P is the polarization vector and Xe is electric susceptibility and D is the electric displacement
-grad(P) = ρbound
P dot n = σbound
Where n is a unit vector normal to the surface
ε = ε0(1+χe)
I am able to solve for Xe and sub it back into the equation for P
So
P = ax/ε0E
And I know that the E from the plates is σfree0
And that C = Q/V and that the sum of the bound charges should be zero because otherwise conservation of charge would be violated so V should be changing.
But I am really unsure what to do to figure out the total electric field.
Are you trying to solve for the capacitance or the E-field? I'm assuming the capacitance since that was one of your relevant equations and typically for a parallel plate capacitor, that's what you're looking for.
A few equations to get you started:
E_n*\epsilon(x) = \rho_s where E_n is the normal component of the E-field and \rho_s is the surface charge density on the plates. If you use \rho_s and substitute in for the charge and area, then solve for the potential V using:
V = -\int_{0}^{d}E\cdot dl
You should be able to get the capacitance from there.
I atually ended up figuring it out, but it was really crazily easy. Basically I was supposed to use the electric field from a parallel-plate capacitor and substitute in ε for ε0 then integrate to find the voltage.
9K
