Can someone explain the negative sign in the capacitance formula?
The discussion revolves around the confusion regarding the negative sign in the capacitance formula and its implications in calculating charge. A user calculated the charge on capacitor plates as -0.9 C using the formula We/q = ΔV, but the textbook states the answer is 0.9 C. The user notes inconsistencies in how the negative sign is treated in different contexts, particularly regarding work done against the electric field. It is clarified that when the electric force acts in the same direction as displacement, it does positive work. Understanding the context of the negative sign is crucial for accurate calculations in capacitor problems.
James2288
Hi everyone,
1. Homework Statement
It takes 18 J of energy to move a 0.30-mC charge from
one plate of a capacitor to the other. How much
charge is on each plate?
-We/q = ΔV
C = Q/V
-18J/0.3.10-3 C * 15.10-6 F = Q
Q = -0.9 C
The problem is that in the book, the answer is 0.9 C but i found -0.9C. I had many problems with the formula
-We/q = ΔV
sometimes in the book they let the negative sign and sometimes not. If someone can explain me that..
When you move a charge on a electric field, you do work against the electric field. So the work applied is equal to minus the work done by the electric field (assuming no changes in the kinetic energy).
Thank you ...
Can I say when the electric force is exerted in the same direction to the displacement that make a positive work ??
  • · Replies 16 ·
  • · Replies 28 ·
