How Is Capacitor Output Voltage Calculated and Measured?
The output voltage of a capacitor can be calculated using the formula V = Q/C, where V is voltage, Q is charge, and C is capacitance. In the discussed video, a 2.7 Farad capacitor charged with 1 Coulomb yields an output voltage of approximately 0.37 Volts. Capacitors rated for 2.7V can be charged up to that voltage, but actual output may vary due to resistance and leakage. To measure the output voltage accurately, a voltmeter should be connected to the capacitor's terminals, preferably one with high input impedance. Discharging the capacitor before measurement is crucial for safety.
mearvk
The caps are rated for 2.7V
Meaning you can charge them up to 2.7 volts?
Yes, they are designed to accept 2.7V
The output voltage of a capacitor can be calculated using the equation V = Q/C, where V is the output voltage, Q is the charge stored on the capacitor, and C is the capacitance of the capacitor. In the video, the demonstrator is using a capacitor with a capacitance of 2.7 Farads and a charge of 1 Coulomb, which results in an output voltage of approximately 0.37 Volts (1/2.7 = 0.37).
It is important to note that this formula assumes an ideal capacitor and does not take into account factors such as resistance and leakage, which can affect the actual output voltage. To accurately measure the output voltage of a capacitor, a voltmeter can be connected to the ends of the capacitor. However, it is recommended to use a high-quality meter with a high input impedance to minimize any potential errors in the measurement. Additionally, it is important to discharge the capacitor before taking a voltage measurement to avoid any potential safety hazards.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 19 ·
  • · Replies 28 ·
14K
  • · Replies 22 ·
