Titan97
- Messages
- 450
- Reaction score
- 18
What charges will flow after shorting of the switch (Sw) in the circuit below through sections 1 and 2 in the direction indicated by the arrows?
Kirchoff's laws
Initially, both capacitors will have a charge of $$Q_I=\frac{C_1C_2}{C_1+C_2}E$$
Finally, after shorting the switch, potential difference across ##C_1## becomes zero. So final charge on ##C_1## is zero and final charge on ##C_2## is ##C_2E##.
So the charge that flows through section 1 is $$C_2E-\frac{C_1C_2}{C_1+C_2}E$$ But answer given is ##C_2E##.
Edit
Please check if I am correct.
Some charge has to flow through section 1 to make the charge on right plate of C1 zero. That charge is $$-\frac{C_1C_2}{C_1+C_2}E$$ since initially, the right plate had a positive charge of magnitude ##Q_I##.
Now, to make charge on left plate of C1 zero, a charge of
$$\frac{C_1C_2}{C_1+C_2}E$$ will flow from upper plate of C2. (Assuming the charge can't flow through the battery). So this makes C2 lose all its initial charge and after shorting the switch, ##C_2E## flows in section 1. Hence I got the given answer.
But is my assumption correct?
