Capacitors charged to voltage in parallel
The discussion centers on the behavior of two capacitors connected in parallel, one with capacitance C charged to voltage V and the other with capacitance C charged to voltage 2V. When connected, the total charge redistributes to achieve a common voltage across both capacitors. The charge on each capacitor is calculated using the formula Q = CV, leading to a final voltage of 1.5V across each capacitor after connection. This demonstrates the principle that components in parallel share the same potential difference.
  • Understanding of capacitor charging and discharging principles
  • Familiarity with the formula Q = CV for capacitors
  • Knowledge of electrical circuit theory, particularly series and parallel connections
  • Basic algebra for manipulating equations
  • Study the concept of charge conservation in electrical circuits
  • Learn about energy stored in capacitors and how to calculate it
  • Explore the differences between series and parallel capacitor configurations
  • Investigate the implications of unequal capacitances in parallel connections
Students studying electrical engineering, physics enthusiasts, and anyone looking to deepen their understanding of capacitor behavior in circuits.
Ineedahero
Suppose you have a capacitor with capacitance C charged to voltage V and a second capacitor with capacitance C charged to voltage 2V. The two capacitors are connected in parallel. What will be the voltage across the two capacitors after being connected in parallel?
Q = CV
These kinds of questions confuse the hell out of me.
What does it have to do with a parallel connection? What's the difference if it was in series?
I know that for a parallel connection, the charge is constant throughout, and for a series connection the voltage is constant throughout...but what does that really mean? How do you apply it?
I really see no possible way to solve this, but at the same time I feel like it's simple.
What are you supposed to do here??
Q = CV
That's exactly backwards: Components in parallel must experience the same potential difference across them (since their connections share the same pair of nodes). Components in series share the same current (since there's nowhere for it to go except follow the single path through them).
Here you've got two charged capacitors with different voltages on them being connected together in parallel. The charges on these capacitors will have to redistribute in order to achieve the same voltage across both (parallel --> same potential difference). Charge is a conserved quantity.
So start by working out the charge on each (symbolically). How will you distribute the total charge so that the capacitors will have the same potential difference?
Before we leave this problem, just for fun, calculate the energy stored in the two capacitors before connecting them together and the energy stored in the capacitors after connecting them in parallel. Where did the energy go?
Thanks for the help!
Here's where I'm getting stuck - you say to work out the charge on each. Well, how do I calculate the charge??
I know that q = cv. I also have, essentially, two capacitors connected in series - once I find the equivalent capacitance of the two capacitors connected in parallel.
So that leaves me with two capacitors of 14 connected in series. I know that the charge is constant throughout both of them...but how do I find it??
q=cv = 14 * 12 = 168...but what if the capacitors weren't of equal capacitance? Then that formula wouldn't work...
Don't get ahead of yourself :smile: Start by finding the charge on each capacitor before they are connected to each other. What's the total?
I don't know where these numbers are coming from; the problem only uses symbolic values (C,V).
Also, while you can interpret two components connected together to be either in series or in parallel, in this sort of problem you'll find it easier to interpret the connection in parallel fashion. This is because you can make use of the equal potential difference criteria of parallel connections and the equation you already have for the potential across a capacitor (V = q/C).
If the capacitances were not equal then you'd need to write a pair of equations and solve for the individual charges; the total charge being a constant and potentials across them being equal.
Hmm
Q1 = C1V1
Q2 = C1*2V1
Q1 + Q2 = 2C1*3V1
Is that correct?
Right idea, but check your algebra.
Of course, what a silly error!
Q = 3C1V1
Q = 3C1V1
Okay, that looks better. So now, how will that charge be distributed on the two (equal) capacitors when they are connected in parallel?
Well, since the voltage is constant (since they're in parallel), and the capacitances are equal, the charges must also be equal.
So the charge will be cut exactly in half and go to each capacitor?
That's correct. So what's the resulting voltage on one of the capacitors?
Hmm
Qeach = 1.5*C1V1
The capacitance doesn't change, but the voltage does.
Qeach = C1V2
1.5V1 = V2
So the new voltage is 1.5 * the original voltage?
Yup.
Ok!
Thanks a lot for the help!
