Capillary forces, intermolecular forces and surface tension questions
The discussion centers on the mechanics of capillary action, specifically how water is drawn into a capillary tube by adhesive forces. Once the water drop is fully drawn in, the forces balance, halting further movement. A key question raised is about the upward movement of the top water molecule and how other molecules can "leapfrog" it. Additionally, the relationship between capillary pressure and tube radius is explored, questioning why smaller diameters create higher pressure and how adhesive forces dominate over cohesive forces in this context. The conversation suggests that understanding these phenomena involves both continuum and atomic concepts, with a focus on pressure differences and force balances rather than individual molecular behavior.
Pete2s
I tried posting a similar question before, however, I've found the 1 reply is actually wrong. Hopefully with better illustrations, someone will know.
The situation in the picture is a drop of water entering a capillary tube. It is located here: http://img207.imageshack.us/my.php?image=capillaryaction2yi2.png
Correct me if I'm wrong, but the drop is drawn into the tube by the adhesive forces of the water to the capillary tube. Once the entire drop is drawn in, the forces equal out and the water stops moving up: the bottom water molecules are pulling down with the same force as the top is pulling up.
Question #1: as shown in the zoomed-in red square, what is making the top water molecule move up? If it isn't moving up, how are other water molecules leap frogging it and pulling more water up with them?
In the bottom diagrams, we have cone-shaped capillary tubes. I know that the capillary pressure is directly related to the radius of the capillary tube.
Question #2: It's my understanding that the water would move up to the top in the cone capillary tube because of the pressure difference. But why is there more pressure when the radius becomes smaller? Why would a water molecule that's stuck to the side at the bottom in the 3rd tube want to move up? It can't be the cohesive forces of the water pulling it up--the adhesive forces are stronger than the cohesive forces, that's why we have the capillary action.
Thanks for any help.
Should I post this in the advanced forum? Does anyone know someone who might be able to answer?
One conceptual problem here is mixing continuum concepts (interfaces, wetting) with atomic concepts (molecules 'leapfrogging').
There has been some work on molecular modeling of wetting (Joel Koplik), but don't concern yourself with that yet.
The curved interface represents a pressure jump across the interface, and the contact angle represents a force balance between the two fluids and the two fluid-solid interfaces. Don't worry about what individual molecules are doing, it's not relevant.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
