Solving Car Banked Problem: Friction Force at 88 km/h
  • Thread starter Thread starter confusedaboutphysics
    Car
The discussion focuses on calculating the friction force required for a 1300 kg car rounding a banked curve with a radius of 70 m at a speed of 88 km/h and an angle of 12°. The equations of motion are established as the sum of vertical forces (Fy) and horizontal forces (Fx), leading to a system of equations that includes the normal force (Fn) and frictional force (Ffr). The solution involves using substitution to isolate Ffr from the equations, which are derived from Newton's second law.
  • Understanding of Newton's laws of motion
  • Familiarity with circular motion concepts
  • Knowledge of trigonometric functions in physics
  • Ability to solve systems of equations
  • Learn how to apply Newton's laws to circular motion problems
  • Study the effects of banking angles on frictional forces
  • Explore methods for solving systems of equations in physics
  • Investigate the role of centripetal acceleration in banked curves
Physics students, automotive engineers, and anyone interested in the dynamics of vehicles on curved paths.
A 1300 kg car rounds a curve of radius 70 m banked at an angle of 12°. If the car is traveling at 88 km/h, how much friction force is required?
ok so this is what i did so far but i got stuck.
the sum of Fy = mg - Fncos(angle) + Ffrsin(angle) = ma = 0
the sum of Fx = Fnsin(angle) + Ffrcos(angle) = ma = mv^2/r
i don't know how to get Ffr alone from here...help please!
In your math courses this would have been called a system of equations. Your system here is 2 by 2 (2 equations, 2 unknowns). You can solve it by substitution. That is, solve for one of the variables in one of the equations, and then substitute the result into the second equation to eliminate one variable.
so are my two unknowns Ffr and a?
No, they are the frictional force and the normal force. You do know a.
  • · Replies 20 ·
  • · Replies 17 ·
