Car turning with external force help from spoiler
When a car turns, the tires generate centripetal force directed toward the center of the turn, and the discussion explores whether a spoiler can assist in this process. The proposed spoiler configuration aims to create additional lateral force, potentially reducing strain on the rear tires during a turn. However, it is argued that using airflow to control a car's movement could lead to loss of traction and increased likelihood of fishtailing. The consensus suggests that while a spoiler can provide downforce for better traction, it may not effectively reduce the force on the rear wheels as intended. Understanding the relationship between lateral forces and yaw is crucial for optimizing car handling during turns.
mark77
Ok, so when a car turns, the tires provide the acceleration pointing toward the center of the turn. If for some reason, I put a spoiler on my car with two rectanglular pieces, one on each side that are tilted, to the left, mocking an airplane rudder, thus when the wind has contact with them, there is a force with a component backwards and to the right. If my car is turning to the right with this spoiler system, this will help with the turn and take some of the force off the tires, or even allow the car to take the turn faster as now the tires can have the same maximum component of before and then the extra from te spoiler (correct me if I am wrong). Also, with this system, how do I ensure that yaw still occurs around the proper side and the car rotates arround a corner? Thanks for the help.
If I can get anyone of the questions answered, the most helpful for me would be if I took a corner at the same speed with and without the spoiler, the lateral friction on the wheels would decrease with the spoiler than without it...?
I am not an expert but, if I understand correctly, a "rudder" is not really going to do a lot - it might be be detrimental. Anything that turns the car, that is not related to the wheels is actually going to increase likelihood of a fishtail or spin out.
The idea is to is ensure the spoiler applies a maximum downforce on the rear wheels so the car doesn't fishtail.
Ok, thanks for the help. My way of seeing this is that to go around a turn you need x amount of cent. force. With the spoiler in place allowing for an extra component of force towards the center of the turn, the force towards the center in the rear wheels decrease by the amount of the force that is now in the spoiler a that way the cent. force remains x...I don't think the force of the rear wheels remains the same is my point. I believe it decreases by the amount of cent force acting on the spoiler. I am not sure tho, I would need some kind of evidence forme to change my mind...
Thanks again for your input though Dave
I cannot imagine any spoiler configuration that would lessen the force on the rear wheels; it would have to pull the rear of the car inward.
I guess if you were making a sharp left turn and you turned your "rudders" hard right (exactly opposite to what you'd do in an airplane), it would result in the rear of the vehicle experiencing a force to the left, which is what you're looking for.
Yes, exactly with that configuration set up let's say
before
after
where bottom is force on tires and top is on spoiler
this way total cent. force is the same ( 4 "bars" as an illustration), just location of force is a bit different. So will something like this occur or no?
before
after
But to do so is to generate a strong force that wants to turn the car exactly the opposite direction you want to go. The moment you turned left, your rudders would try to turn your car right. This is not good for control.
Hey, Dave I am a little confused on what you mean here. If the "rudder" is angled so the front is to the right, back is to the left and I turn right, there would be a force with components to the right and to the back on the rudder, thus that should help with turning as the right is were the centripetal force needs to be, not the opposite way...
adding a rear spoiler to a " stock car" will provide minimal additional turning capability. It may in fact take away total performance.
Question- what are you trying to accomplish? Are you talking about round track racing only? road course? street racing?
I suggest you read Race car suspension Class in this forum to gain insight on what happens when you turn left
Round track, thus the rectangular sides of the "spoiler" will be angled in a similar direction (with the left towrad the front, right toward the back for a left loop.
But that's not what you'd want.
Assume you want to make a left turn (I am imagining you are going around the track counter-clockwise).
To cause the rear of the car to experience a force to the left (taking strain off the rear tires), your rudders would have to point front-to-left, back-to-right - as if it is making a right turn.The problem you're encountering is that a car is not an airplane. A car gets its drive and direction from its wheels, not the flow of air. A car pivots on its wheels. If you attempt to control its movement by way of air, you end up moving the wrong parts of the car. The most obvious example is that any airflow that puts torque on the car will work to make it more likely that the wheels will lose traction.I've thought of a way you might be able to get this to work but it'll need some verification: place the rudder at the central vertical axis of the car (i.e. where a taxi has its light). In a left turn this will provide a force that pushes the car left (which is good), but does not impart a torque on the car (which would be bad).
mark77
what is the purpose of this rear spoiler?
why are you thinking of adding it?
what reason?
also thanks for the PM..slip angel and cornering G force is covered in the race car suspension class
Dave 426913
To cause the rear of the car to experience a force to the left (taking strain off the rear tires), your rudders would have to point front-to-left, back-to-right - as if it is making a right turn.this is not correct..rear spoiler adds "strain" on rear tiresThe problem you're encountering is that a car is not an airplane. A car gets its drive and direction from its wheels, not the flow of air. A car pivots on its wheels.
Dave..some what true but the suspension pivots thru its roll centers.
dave..depending upon the race car, and aero package..spoiler can add huge amount of down force on the rear tires, thus huge traction advantage. I think you are correct about air flow under the car with no provision for channeling air over the top side will cause the front end to float..usually about 130 mph (my experience) and the steering gets way spooky and loose
read the following posts
Tire Slip Coefficient
Apr2-10, 07:57 AM
Aerodynamics of sportscars
Mar9-09, 07:41 PM
Calculating G Forces or the Centripical force
Dec27-08, 01:43 AM
Race car physics
Dec29-08, 11:31 AM
does friction increases as speed increases?
Dec31-08, 07:37 AM
Tyres - why is wider better for lateral grip?
Nov5-09, 11:38 PM
Mike, please use the quote feature, or it becomes very difficult to read posts.
Ranger Mike said:
mark77
what reason?
The OP has explained that he wants to takes strain off the tires.
Ranger Mike said:
Dave 426913
You are not following along.
A spoiler provides downforce, true, but Mark77 is talking about a vertical spoiler to create lateral forces.
No that's not what I'm saying. When I say pivoting I mean yaw, not roll. I'm saying you can't use airflow to turn the car because it gets its traction for turning into a corner via the wheels. If you try to use airflow to turn the car, you will get slippage and lose traction.
Again, Mark77 wants to talk about lateral forces.
I've explained that the idea is really to provide downforce on the rear wheels, which will provide traction. But Mark77 is speculating about reducing stress on wheels, so we're talking about lateral forces.
I agree with what you are saying above Dave, I am looking more into lateral forces. I also see where you are going when it comes to the yaw, which is were I stil am not 100 percent sure. First of all, do you agree with me that strain is taken off the rear tires on a turn, if not why? Also how will yaw be affected if the same size components of force will remain on the rear and front. I honestly don't really understand the concept of yaw on cars too well so any help on that if I am wrong or right would be great.
Thanks,
Mark
Well, there is certainly little strain on the tires if the car continues to go straight, instead turning left - which is exactly what the rudders are trying to do - cancel out the turn (by applying a leftward force at the rear of the car, causing the the car to want to pivot to the right).
As tyres are the only points of contact all forces must go through them.
All an angled spoiler will do is alter (read: ruin) the balance of a car. Angled wings were used on open wheel oval racing years ago but were ditched for destroying aero balance and shredding the tyres on straights.
Ok, any ideas on how I can make the car do the "yawing" part of the turn with this system in place. More weight in the front?
Also, Dave I am thinking about placing the spoiler directly abpve the CG that way the foprces will only go towards roll as opposed to torque because I think there are complications neither of us know about specially the yaw aspect (as I am no car expert either) having it back there. Any improvements in car handling youll see by having it at the top, or any tips in general...thanks
What on Earth are you trying to do?
Pretty much by having the spoiler above the center of gravity, if I have the rudder at the right angle for a certain turn angle, I should be able to counteract the roll and thus the weight/load transfer and optimize friction on the wheels. Will this work?
In a word. No.
Start at the beginning and talk about what you want to achieve. What is the car? What is the application? etc.
Also what is written above shows a lack of understanding about how a car turns. Seriously read through the suspension thread as I think it has a section on slip angles.
I understand that cars have a centripetal force lke anything else exedrted on them by an external force in order to turn. When a car turns the patch of tire in contact with the ground is altered due partly to inertia and thus the car does not follow the direction the wheels are pointing, which is were the slip angle comes into play. The force on the tires from the ground on a turn, or the lateral force occurs (which depends on the slip angle) and contributes to both drag and the centripetal force. Anyways, I am no expert on this subject which is why I am the one asking the question as opposed to answering it, so any INPUT would be appreciated. So if there is something missing help me out.t
Now, how would the spoiler above the CG not work? There will be a small addition of force on top of the car in the opposite direction of theCG causing a roll torque in the direction opposite of that caused by the lateral force. The tires will still be in contact with the ground with just a little less grip but in proportion to each other...
That is extremely confusing to me, as I'm not really sure what you are proposing and why you think it will be an improvement.
The lateral acceleration causes cornering through the slip. It also causes load trasfer to the outer wheels. Load transfer is not the same as weight transfer. You are proposing something that would create a force acting opposite to this (it mat or may not depending on which way the wind is blowing at the time). Any force acting opposite to this means you have a reduced lateral force for a given slip angle. So you reduce your cornering ability.
Also roll has little to do with load transfer.
It's like saying that you want to increase your acceleration in a front wheel drive car by adding a rear spoiler.
First, Mark, what you are describing is a wing, not a spoiler.
Second, yes, a vertical wing can be be used to generate force in the direction of the turn and either lessen the force needing to be generated by the tires for the same cornering speed or to increase the overall cornering speed (usually the reason for using them!). Winged dirt Sprint cars have very large side panels that do exactly that, although the panels are just flat and not wing shaped. Because of the large slip angles that these cars use while cornering on dirt, the side panels have a significant angle of attack and generate enough force to justify using them.
Third, having the force from the wing acting above the roll centre of the vehicle will counteract the vehicle's typical roll reaction to the forces generated by the tires while cornering. Again, dirt Sprint cars with large side panels on their wings benefit from this, reducing the amount of roll that the car experiences while cornering. This allows the use of softer springs and anti-roll bars which generally allows the tires to work better.
http://www.world-sprintcar-guide.com/sprint-car-wings.html
Thanks Mender, I did not exactly see a problem with the wing and its placement and am glad to see thistechnology is being used. Now can you give me a recommendation? I am thinking about having the wing produce a roll towards the inside of the curve, thus reducing the weight on the outside tires and distributing it more equally among all four as I have read this should help in cornering as when vertical load increases it lateral force increases but after a while does so at a decreasing rate. First, will this work the way I am imagining? Second, will the car still turn and handle properly on TURNS any improvements? Thanks for the help. Mark
This is an all sweeping answer that is is only valid in certain situations.
You mention sprint cars, they run on ovals and are only required to turn one way.
The ovals are generally banked.
They are running at a fair bit of speed.
And an angled wing would increase force per slip angle for a given load, which can't really be described at reducing the load on the tyres.
It'll certainly cancel the tendency to roll, but certainly won't stop load transfer.
So if he takes this knowledge from 140mph sprint cars that only turn left, and sticks a fin on the top of his Lacetti (or other reasonably priced car) and and sets off into the wild blue yonder. Whats going to happen?
thanks chrisxxx for replying as i was tied up at work. There is a basic lack of understanding of what happens when a car turns left (or right). Please read the info on suspension and this way everyone can use the correct terminology and have a fundamental baseline we can build on.
As Crisxxx has noted, and as have I in previous posts..it is all about tires.
No where in this post have we discussed what happens during turn entry, mid turn and exit.
The car does not pivot on wheels it pivots thru the roll centers and force is applied to the tires. Lateral force is applied applied as is down force and forward force when the car enters a turn.
Adding a spoiler or wing will not reduce "stress or strain " on the tires, in will most likely reduce the effectiveness of weight transfer and hurt overall performance.
When you add a "vertical spoiler" all you are really doing is adding more tire load in an attempt to improve traction in the turn..if i follow the line of thought presented. Unless you bump up spring rates what you just did is wash out the spring rate that was tuned to handle the load. Actions have consequences.
You can use aero dynamics (air flow) to assist in turning the car and increase traction. Indy cars have so much down force caused by their aero package that theoretically they can drive upside down. This package must be coordinated with the entire suspension and tires or serious problems will occur.
From what I am reading, you feel that reducing roll will also reduce the load transfer; not so. As has been mentioned, it won't change the load transfer from cornering. That is determined by the height of the Centre of Gravity of the vehicle above the ground and the track width.
Roll is controlled by the stiffness of the springs and by the size of the anti-roll bars. Together they add up to the roll stiffness of the car. By increasing the roll stiffness, roll at a given cornering rate is reduced and can be effectively zero if desired - but that doesn't bring the load transfer to zero as you seem to think. All it does is effectively make the suspension solid when cornering, basically making the suspension useless but with no change in load transfer.
As an example of that extreme, a go-kart has no suspension and therefore no roll but still has load transfer as dictated by the C of G and track width; by your way of thinking it shouldn't, right?
No; see above.
In theory your wing would help the car by adding aerodynamic side force to that being generated by the tires, and yes the car would still turn but the handling would be slightly different. So you are a little bit right but not for the reason that you're thinking of.
The Sprint cars obviously benefit from them but are a special case as Chris mentioned. The reason I mentioned the dirt cars is that they typically corner with quite a bit of slip angle on the dirt, which would give the side panels (or vertical wing) a reasonable angle of attack. If the wing was neutral to the car (i.e., aligned fore and aft), the wing would generate side force when cornering in either direction. On pavement, the slip angles are much less and the car would likely not benefit much unless the wing could move like a rudder (not legal in any racing classes I know of).
In practice, a road car would be much better off using a horizontal wing or a spoiler to increase downforce on the tires to increase traction.
Sorry to burst the bubble; interesting question though, it shows that you're thinking about things! Don't stop asking questions!
this is indeed the essence of his idea. Movable rudders.
  • #31
As you can't gaurantee the airflow, all a movable rudder will do is make it seem like you are driving in a constantly changing cross wind.
Even in theory, you are still limited by the amount of lateral grip the tyres can withstand.It's an interesting concept though.
  • #32
His idea is that the rudders would actively engage when turning.
The whole point of what he's proposing is to use aerodynamics to lessen the dependence on lateral grip. If the car is assisted through its turn, there is less strain on the tires, therefore less likely to slip. (Taking the principle to its extreme: If one used the Batmobile/Mythbusters "grapple-gun technique" to turn corners, then the dependence on lateral grip of tires is reduced to zero - just substitute still air for telephone pole. :biggrin:)
I am not condoning the idea; I don't think it will work either. I think it will render the vehicle uncontrollable. But I am not an expert in this field. I just want to make sure he gets the best answers possible based on correct information.
  • #33
How would it do that?
  • #34
Powerful transverse forces on the vehicle right in the middle of a turn?
  • #35
I'm not sure how you're visualizing this, but I can tell you that powerful transverse forces are always acting on the car during cornering, ones that are not always balanced or predictable, and the driver is expected to compensate accordingly.
I'm not seeing a situation that renders the vehicle uncontrollable, so if you have one in mind I'd be interested in reading about it.
  • #36
Essentially, a VERY powerful gale force gust of wind is going to hit the car crosswise, the moment it goes into a turn, and then stop the moment it leaves the run.
  • #37
Hey guys, first off, thanks for all your input. In terms of this quote above, can't you cancel load transfer by adding a torque opposing the torque that is causing it (normal force and lateral friction force). Correct me if I am wrong but the load transfer happens because of a torque from mostly firction (some normal force as well) on all four tires as going arround a turn, they would be in similar directions thus producing a torque that is thus "countered" by increasing load on one side and decresaing the one on another. Again correct me if I am wrong I am just throwing ideas around. Thanks
  • #38
It would require a wing of very large area.
There is much more to reap from negating lift/adding downforce than by using an airfoil to affect a car on the axis we are speaking of.
  • #39
mark77
have you taken the time to READ the posts I noted?
  • #40
No, you can't "cancel" load transfer because you can't cancel inertia. It's quite important (to us anyway) that you understand this fact; can you at least address this so we know where you're at before we move on?
If you are meaning "compensate for the load transfer" (and it certainly sounds like that's what you're proposing), that is another thing entirely, but please, let's make sure you have the first part right, okay?
