Carnot engine with a magnetic auxiliary system
6 replies · 3K views
fluidistic
I would like some assistance to solve the following problem.
A magnetic system satisfies Curie's law ##M=nDB/T##, has a specific heat capacity at constant magnetization ##C_M=\text{constant}##. It is used in a Carnot engine that operates between temperatures ##T_h## and ##T_c## (##T_c<T_h##).
M is the magnetization and B is the external magnetic field.
1)Sketch a qualitative (B,M) diagram of a complete cycle.
2)Calculate the work done by the engine after 1 cycle.
3)Calculate the efficiency of the engine.
##C_M=\frac{T}{n} \left ( \frac{\partial S}{\partial T} \right ) _{M,n}=\left ( \frac{\partial U}{\partial T}\right ) _{M,n}## (1)
1)I've done the sketch, I don't think there's anything particular about it.
2)This is where I'm stuck.
From equation (1) I've determined that ##S(T,M,n)=C_Mn \ln T+f(M,n)## and that ##U(T,M,n)=C_MT+g(M,n)##. Not sure this can help.
I know that the work done is the area enclosed by the sketch in the B-M diagram, namely ##W=\oint B dM##.
I know that in a Carnot cycle there are 2 adiabatic and 2 isothermal processes. Also the 1st law of Thermodynamics states that ##\Delta U =Q+W## so after a cycle ##\Delta U=0## and so ##Q=-W##. In other words the heat toward the auxiliary system is equal to the work done BY the system. And since there are 2 adiabatic processes (no heat is being absorbed by the system), I get that the work done after 1 cycle is equal to the heat absorbed by the system during the 2 isothermal processes.
Now if I think of M as a function of B, T and n and assuming that n is constant for the auxiliary system then ##dM=\frac{nDdB}{T}-\frac{nDBdT}{T^2}##. Note that for the 2 isotherms, ##dM=\frac{nDdB}{T}##.
I also know that ##dW=BdM## and so for the isotherms, ##dW=\frac{nDBdB}{T}##. I know that there's 1 isotherm at a temperature of ##T_h## and the other at a temperature of ##T_c##. My problem is that I don't know what are the limits of the integral if I integrate this expression. So I can't really get W via this expression.
I don't really know how to proceed further.
Any tip is appreciated!
Let ##\small (M_1, B_1)##, ##\small (M_2, B_2)##, ##\small (M_3, B_3)##, and ##\small (M_4, B_4)## be the states on the ##\small B##-##\small M## diagram corresponding to the "corners" of the Carnot cycle. 1→2 is isothermal at ##T_h##, 2→3 is adiabatic (reducing ##\small T## to ##\small T_c##), etc.
So, for the leg 1→2, your limits of integration for ##\small W=-\int B dM## will be from ##\small M_1## to ##\small M_2##, etc.
You want to get expressions for the total work done in the cycle, and for the heat added during the cycle. These expressions will be in terms of the ##\small M_i##'s, the hot and cold temperatures, and the constants ##\small n, D, C_M##.
Oh I see, thanks.
I didn't know I could assume ##M_i##'s to be known.
Following what I had done I reach that ##W=\frac{1}{2nD}[T_h(M_1^2-M_2^2)-T_c(M_3^2-M_4^2)]## (work done ON the system so to answer the question I'd have to set -W to get the work done BY the system). If that's the correct answer then I guess I'm done for part 2). If it's wrong I'm going to post what I did to reach this.
fluidistic said:
Oh I see, thanks.
That's close to what I get, except for signs. The work done by the system is ##\small -\int{BdM}## [Edited to replace the symbol H by B ]. So, I think your first term ##\small \frac{1}{2nD}T_h(M_1^2-M_2^2)## represents the positive work done by the system as ##\small M_1## is reduced isothermally to ##\small M_2## (with ##\small M_2 < M_1##). The work done by the system in going from 3 to 4 (with ##\small M_4 > M_3##) should be negative.
The signs are confusing because you need to reduce M to get positive work done by the system (which is opposite to P-V work where V should be increased to get positive work done by the system).
TSny said:
That's close to what I get, except for signs. The work done by the system is ##\small -\int{HdM}##. So, I think your first term ##\small \frac{1}{2nD}T_h(M_1^2-M_2^2)## represents the positive work done by the system as ##\small M_1## is reduced isothermally to ##\small M_2## (with ##\small M_2 < M_1##). The work done by the system in going from 3 to 4 (with ##\small M_4 > M_3##) should be negative.
So basically I've got the signs wrong?
I know that the total work done BY the system should be positive. My answer to the question would be ##W'=-W=\frac{1}{2nD}[T_h(M_2^2-M_1^2)-T_c(M_4^2-M_3^2)]##. I believe that it's positive but I'm not 100% sure.
I agree with your second term (which yields negative work done by the system in going from 3 to 4), but I don't agree with the sign of your first term (which would also give negative work in going from 1 to 2). As I see it, ##\small M_2 < M_1## and ##\small M_4 > M_3##.
Work done by the system in going isothermally from a to b is ##\small W = -\int_a^b{BdM} = -\frac{T}{2nD}(M_b^2-M_a^2)##.
You are right TSny, I understand my error now. Thanks a lot.
