Cartesian Product and Inclusion - Looking for a Proof
The forum discussion centers on proving the set equality \( A \times (B \cap C) = (A \times B) \cap (A \times C) \). The primary challenge faced by the participants is the use of the Proof Designer software, which complicates variable assignment during the proof process. Specifically, the existential instantiation in the software requires different variable names for elements from sets B and C, leading to confusion in demonstrating that the elements are the same. Ultimately, the proof hinges on correctly interpreting ordered pairs and their relationships within the context of set theory.
  • Understanding of set theory, specifically Cartesian products and intersections.
  • Familiarity with existential quantifiers and their use in mathematical proofs.
  • Experience with proof-writing techniques, particularly direct proofs.
  • Basic knowledge of using Proof Designer software for formal proofs.
  • Study the principles of set theory, focusing on Cartesian products and their properties.
  • Learn about existential quantifiers and how to apply them in mathematical proofs.
  • Practice writing direct proofs in set theory to enhance proof-writing skills.
  • Explore the functionalities of Proof Designer to better understand its application in formal proofs.
Mathematics students, educators, and anyone interested in formal proofs and set theory, particularly those using Proof Designer for their studies.
Kolmin
Prove that
A\times(B\capC)=(A\timesB)\cap(A\timesC)
In particular what I cannot prove is
(A\timesB)\cap(A\timesC)\subseteqA\times(B\capC)
In order to learn how to deal with proofs I am reading How to prove it: a structured approach, and I am using Proof Designer. This is the main problem I think...
First of all, I tried all possible approaches, but still I cannot figure out how to deal the problem I have, which I will explain.
I found various direct proofs of this biconditional (even on the book itself) and, given
\existsa\inA\existsb(b\inB\wedgep=(a,b))
\existsa\inA\existsb(b\inC\wedgep=(a,b))
all assume that this b has to be the same for B and C.
Indeed, if this is the case, the proof is quite straightforward, BUT...we cannot assume so - at least using Proof Designer. As a matter of fact, the software, using the existential istantiation, asks you to choose a certain name (let's say a_{0}) and that's the problem. In the first expression I can put a_{0} and b_{0}, but in the second one, I cannot force the program to use the same variables, because they are already being used, so I have to use something like a_{1} and b_{1}. And that's the problem I guess, cause if I could put a_{0} and b_{0}, the proof would be trivial.
Quite instructive, in order not to use the same object for two different things simply because it helps us to get a wrong proof, but I cannot figure out how to get the right proof!
Kolmin said:
Prove that
Presumably, A, B, and C are sets.
I don't know anything about Proof Designer, so I can't help you with that. This should be reasonably easy to prove using nothing more than paper and pencil.
Let x = (u, v) be an ordered pair such that u ##\in## A and v ##\in## B ##\cap## C. Show that it must be true that ##x \in (A X B) \cap (A X C)##.
Tip: When you're doing LaTeX, it's better to use a small number of tag pairs rather than a large number of tag pairs.
First of all, thanks for your answer.
Yeah, right!
I start to think that micromass' recent thread was related with my crazy usage of LaTex...:smile:
Ok, I think I know what you mean and - as I wrote - I found various proofs of this problem, but maybe I didn't make explicit the kind of problem I have. The problem does exist for me, Proof Designer simply makes it evident.
So having the sets A, B and C, we have to prove
(A \times B) \cap (A \times C) \subseteq A \times ( B \cap C)
which means that
\forall p (p \in (A \times B) \cap (A \times C) \rightarrow p \in A \times ( B \cap C)).
Now, we let p be arbitrary and then we proceed with a direct proof and assume the antecedent p \in (A \times B) \cap (A \times C), which is nothing more than p \in (A \times B) \wedge p \in (A \times C).
For the conjunction elimination rule we get p \in (A \times B) and p \in (A \times C). And here there is my problem...
What you adviced me to do is to take a v \in B \cap C, however given the steps I have showed you, I cannot really do it, and that's exactly what the software makes explicit. In particular the two previous expressions can be rephrased in the following way
\exists a \in A \exists b \in B (p=(a,b))
\exists a \in A \exists b \in C (p=(a,b))
but these b are not really the same, as far as we don't prove it.
[In terms of the software, with the existential instatiation rule, you insert in the first case a_{0} and b_{0}, and in the second something else like a_{1} and b_{1}. Indeed, b_{0} is not b_{1}.]
I hope I clarified what my problem is.
It seems to me that you are pushing symbols around, without realizing what the symbols represent. It might be helpful to draw a diagram or two to help you get thinking in the right way about this stuff.
Why use LaTeX for A, B, and C?
which means that
Right, and I would use different variables.
Let p1 = (a, b)
Let p2 = (a, c)
Now it should be obvious what sets the elements a, b, and c belong to.
Everything hinges on the 2nd coordinates of p1 and p2.
(A X B) ##\cap## (A X C) could be the empty set (if B has no common elements with C), which is a subset of any other set.
On the other hand, what do you get if B and C do have a common intersection?
Thanks.
In the end I found the proof. The problem is that, when I use the software, I want to find a proof that works there (it's a sort of competition between me and the machine).
I would say it's a matter of taste.
Let p1 = (a, b)
Let p2 = (a, c)
I completely agree on using b and c. I used b in both cases simply to emphasize my problem.
On the contrary, I don't agree on using the sub for p, cause I think it could be misleading. Indeed, as far as I found out, the final step that I couldn't see is that, given p=(a,b) and p=(a,c), we get (a,b)=(a,c), which is a=a and b=c.
Anyway, thanks again.
I try to avoid the use of LaTeX unless it is necessary. I page with plain text loads pretty quickly, but a page with lots and lots of LaTeX has to be interpreted by the browser, which takes it longer to load, at least in my browser. With that in mind, it seems silly to me to write ##A## (in LaTeX) instead of just plain A.
Mark44 said:
Let p1 = (a, b)
Let p2 = (a, c)
It's misleading to write p = (a, b) and p = (a, c). When you do this you are implying that b = c. You should not assume that an ordered pair (a, b) is the same ordered pair as (a, c). That's why I used subscripts on p.
I have the same problem. If I'm posting and I say, Let A and B be sets ... then later I write some LaTeX expression involving A and B, it annoys me that A and B appear different when I don't LaTeX them. So I often enclose standalone letters in tags because I want the variables to look the same.
After all, when reading math, one does not necessarily assume that A and A represent the same object. It's commonplace to use a fancy font upper case letter to stand for a family of objects denoted by a plain-font version of the same letter. For example:
Let \mathcal{A} = \{A_i\}
The different fonts applied to the two instances of the letter 'A' signal the reader that these are two distinct variables.
So if I say: Let A and B be sets, and let A \cap B denote their intersection; an experienced reader of math would regard this as a notational error or ambiguity.
One of the reasons I participate here is to learn LaTeX, and I'd appreciate guidance on this issue. I've always assumed that you should mark up every occurrence of a variable the same way if you are implying the same meaning.
I would be very surprised if someone on this forum would give this any thought at all.
My objection still stands. There is a cost to the use of LaTeX. Some pages with lot of LaTeX (including copied passages) take a very long time to load. Speaking for myself, if it becomes too much of an effort to read what someone has written, I start to think that maybe my time could be better spent elsewhere.
Don't get me wrong. I'm not saying that you (or the OP) shouldn't use LaTeX. But I am saying to use it judiciously.
I see what you mean but in this case I think it's part of the assumptions I can take.
Mark44 said:
Let p1 = (a, b)
Let p2 = (a, c)
If I use the subscripts, then I must assume something different, that I cannot really do (at least on Proof Designer), which is that both a are equal.
