Understanding the Results of gcd(x,n)
  • Context: Undergrad
  • Thread starter Thread starter Peter_Newman
    Gcd Number theory
The discussion centers on the properties of the greatest common divisor (gcd) when dealing with integers x, n, and prime factors p and q, specifically under the condition that p divides x and n equals p multiplied by q. It is established that if p divides x, then gcd(x, n) can only be either n or p, depending on whether q divides c, where c is defined such that x equals c multiplied by p. The reasoning confirms that if q does not divide c, gcd(c·p, p·q) equals p, while if q divides c, gcd(c·p, p·q) equals n.
  • Understanding of prime factorization
  • Familiarity with the concept of greatest common divisor (gcd)
  • Basic knowledge of divisibility rules
  • Ability to manipulate algebraic expressions involving integers
  • Study the properties of gcd in number theory
  • Learn about the Euclidean algorithm for calculating gcd
  • Explore the implications of prime factorization in gcd calculations
  • Investigate the relationship between gcd and least common multiple (lcm)
Mathematicians, students studying number theory, and anyone interested in understanding the properties of gcd in relation to prime factors.
Peter_Newman
Hello,
I read something about to which I have a small question of understanding. Before I would like to outline it a little. So we have the primes ##p## and ##q## and we know ##p|x## and ##n = p\cdot q## furthermore it follows that ##p|n## also holds.
Now it was said that if ##p|x##, then ##\gcd(x,n)## is either ##n## or ##p##. Why is this so? I had a few thoughts that I would like to share here.
Consideration 1:
From ##p|x## it follows that there is a ##c## such that ##c \cdot p = x##, I simply put this into the ##\gcd(x,n)## and rewrite this a bit, I get ##\gcd(c\cdot p, p\cdot q)##. This is exactly ##n## if the ##c=q##, because ##c## cannot divide either the ##q## or the ##p##. (gcd of two equal numbers, is that number)
Consideration 2:
I again use the approach as before, ##\gcd(c\cdot p, p\cdot q)##. So this is ##p## exactly when ##c \neq q##, because then the only (common) divisor can be the ##q##.
I would be interested to know if the reasoning is correct.
If ##n = pq## then the only divisors of ##n## are ##1,p, q, pq##.
Then the two cases are whether ##q## divides ##x## or not.
It's not a case of ##c =q##, it's a case of whether ##q## divides ##c##.
Hello @PeroK , can you explain this a little further? From there, it is not really clear to me, how one then comes to the assertion "if ##p|x##, then ##gcd(x,n)## is either ##n## or ##p##".
I left that bit for you to do. Look at the two cases I mentioned.
OK, then I would get started:
If the ##q## does not divide the ##c##, then ##\gcd(cp,pq)=p##, I would argue that the ##p## is the greatest common factor (in the expression of the gcd()). Is stat okay?
Yes.
Thank you @PeroK .
I have to admit, however, that the other part of proving "feels" kind of weird.
If the ##q## divides the ##c##, then surely the ##\gcd(cp,pq) = q##, but that can't be? Surely it should be shown that then the ##n## results?!
Peter_Newman said:
Thank you @PeroK .
You're looking for the greatest common divisor. And ##pq > q##.
Try ##c = qd## if you are still unsure.
Oh, now I see what you mean! Yes, of course that is absolutely right! If the ##q## divides the ##c## that means exactly ##k\cdot q = c##... Insert and one sees the "magic". Many thanks @PeroK !
  • · Replies 23 ·
  • · Replies 31 ·
  • · Replies 21 ·
  • · Replies 0 ·
  • · Replies 26 ·
