Cathode ray tube, Voltage needed to move the beam impact spot
The discussion centers on calculating the voltage required to move the beam spot across a cathode ray tube screen. The initial calculations involve determining the electron's velocity and the angle of deflection, with attempts to apply kinetic and potential energy equations. Confusion arises regarding the correct interpretation of the deflection distance and the total velocity needed for accurate calculations. Participants suggest considering the vector nature of velocity and the need for a detailed sketch to visualize the scenario. The conversation emphasizes the importance of correctly applying physics principles to solve the problem effectively.
Opo
Question: A cathode ray tube in a TV has an electron gun operating at 10 kV.
a: What is the velocity (in m.s-1) at which the electrons are emitted? Answer:5.9x107
b: How many volts are needed between the deflector plates to move the beam impact spot across a 70 cm screen if the screen is 120 cm from the deflector?
Tan(θ)=vE/vI
1/2mv2
QE=qV
First attempt:
So first I worked out the angle the beam has to move which was 30.3 degrees. Then I used the equation Tan(angle) = velocity in the direction of the field/ initial velocity. Which was Tan(30.3) X 5.9x107 = 3.4x107
Then I used 1/2 x 9.1x10-31 x (3.4x107 )2 to get 5.3x10-16 <I think I'm going wrong here. When I read through the lecture slides things become limited.
then PE = qV, so PE/q = V, so 5.3x10-16 / 1.6x10-19 = 3287
Then I was given this advice:
The problem is that velocity is a vector quantity, while energy is not.
So it seems that you appropriately worked out the velocity in the direction of the field. (I'll call this ve, and the initial velocity vi)
What you should do then is find the total velocity vtot=sqrt( ve2 + vi 2 ). You then use this number to find the total KE of the electron. Subtract the initial KE (find with vi) and this gives you the energy (PE) which must be added by the electric field."
So I tried this, sqrt(5.9x1072+3.4x1072) = 6.81x107
So Total KE = 0.5x9.1x10-31x6.81x1072 =2.11x10-15
Initial KE = 0.5x9.1x10-31x5,9x1072 = 1.583855x10^-15
2.11x10-15 - 1.583855x10-15 = 5.26145x10-16
Then QE=qV, so QE/q = V
So 5.26145x10-16/1.6x10-19 = 3288.40625 But this is also wrong.
If the screen is 70 cm wide, doesn't the defection have to be only half of that in one direction, half in the other direction, in order to cover the full width of the screen?
So how should I adjust my answer ? I went from 70cm to 35cm (if that's what you meant?) which changed the angle from 30.3ο to 16.3ο but the answer is still wrong.
What transverse velocity did you find for this deflection angle? (That's the velocity component due to the deflection).
I think you need to make a detailed sketch of the scenario. How much of the available potential difference can the electron "fall though" between the deflection plates if it enters the plates midway between them?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
