CD4007 Specs: Vtn, kn, Channel Length Modulation
  • Thread starter KeithLucas
3 replies · 24K views · last reply
KeithLucas
I'm looking for the threshold voltage Vtn, the MOSFET transconductance parameter kn and the channel length modulation parameter for MOSFET 6 on the CD4007. Where can I look these values up?
did you try the datasheet ?
would be the obvious starting place :wink:
cheers
Dave
cheers
Dave
Did YOU try the data sheet? Not such an obvious place for what was being asked.
Moving on:
OP, Which FET do you consider to be #6?
The answer would be foundry and process dependent and I doubt it is available on any data sheet. Maybe you can look for a spice model and either read the model (if it is readable), or use spice to extract the data.
Here is a lab example
http://www.ece.ucsb.edu/Faculty/rodwell/Classes/ece2c/labs/Lab_2_2C_2007.pdf
EDIT
Here is the spice model
CD4007 NMOS and PMOS transistor SPICE models
* Typical - Typical Condition
.model MbreakND NMOS
+ Level=1 Gamma= 0 Xj=0
+ Tox=1200n Phi=.6 Rs=0 Kp=111u Vto=2.0 Lambda=0.01
+ Rd=0 Cbd=2.0p Cbs=2.0p Pb=.8 Cgso=0.1p
+ Cgdo=0.1p Is=16.64p N=1
*The default W and L is 30 and 10 um respectively and AD and AS
*should not be included..model MbreakPD PMOS
+ Tox=1200n Phi=.6 Rs=0 Kp=55u Vto=-1.5 Lambda=0.04
+ Rd=0 Cbd=4.0p Cbs=4.0p Pb=.8 Cgso=0.2p
+ Cgdo=0.2p Is=16.64p N=1
*The default W and L is 60 and 10 um respectively and AD and AS
